4th Dec 2006, 12:58 am | #1 |
Help needed with high voltage PSU
Hi guys does anyone have a circuit for a high voltage PSU of the type used for igniting gas appliances at about 10kv
Mike |
4th Dec 2006, 9:27 am | #2 |
Re: Help needed with high voltage PSU
Mike
Someone will probably come up with one, but I did make an electric fencer for a farmer once that used an ignition coil and two 2N3055s as a multivibrator. Killed radios from half a mile away! Our cooker hob is fed from mains and emits sparks (at a guess about 10kV) about 5Hz intervals. My Coleman Northstar petrol lantern seems to give about the same output and runs from a single AA. Don't know if this is of use, or whether you would prefer making one?
Mike. |
4th Dec 2006, 11:38 am | #3 |
I wonder if you could build a portable one to kill peoples' mobile phones when they're playing their crappy music with them on the train every damn morning!? Oh for an EMP gun!
4th Dec 2006, 1:25 pm | #4 |
What do you want the 10KV for?
As for the "noise" from walkmen and the like, I've always thought about making some sort of zapper. Mike. |
4th Dec 2006, 1:52 pm | #5 |
Hi guys thanks for the replies so far. the 10kv is to ignite a gas burner on a kiln I'm building in another life, I'm not really bothered if I build one or buy one as long as it produces the required effect
Mike |
4th Dec 2006, 2:36 pm | #6 |
i have one ac transformer what delivers more then 7kV.
Simply to feed with 230v.. If you like to get it, postage only |
4th Dec 2006, 4:29 pm | #7 |
Hi Mike,
Ask around a few firms who deal with oil-fired central heating systems; an oil-burner ignition transformer might be a simple solution. Cheers, Kat |
4th Dec 2006, 6:17 pm | #8 |
Hi Mike
I've attached a sketch of the igniter in our MFI hob. It produces one spark per press of the button. I don't have any transformer details but I'm sure it can't be too critical. I'd guess a turns ratio of 50:1. as long as its well insulated. The MFI unit is very small, about 2x2x1 in. Joe |
4th Dec 2006, 6:31 pm | #9 |
An old car ignition coil seems like a good place to start for a DIY job. Or a flyback tranny from an old PC monitor.
I wonder if the units used in gas cookers are cheaply available as spares. Manually operated piezo igniters are quite common. There are several varieties here: http://www.bes.ltd.uk/nav_graf/frame...oducts/010.asp |
4th Dec 2006, 6:47 pm | #10 |
An ignition coil feeding a standard spark plug is perfectly good for igniting gas. The spark plug will withstand the heat too. A push switch or sprung toggle switch to replace the points of the standard ignition circuit works fine, with the spark being generated when the switch is released.
