28th Jun 2010, 11:16 pm | #581 |
Re: AVO Multimeter survey
Does this one merit inclusion? An Avo "Electronic Testmeter" made by ACWEECO and bearing the serial number 2292-250. Will need considerable TLC, so is it rare or otherwise worth the effort?
Thank you,
29th Jun 2010, 7:07 pm | #582 |
Phil,
It's not particularly rare, and beyond the scope of the Survey, but it's a useful bit of kit, designed and built to the original AVO standards, and well worth restoring to its original glory. Good luck ! SPCh |
9th Jul 2010, 4:36 pm | #583 |
I have acquired another AVO 8 Mk 3 which was originally owned my Marconi Ltd according to the engraving on the side of the case. Serial Number 49296.1066
NEIL.
An engineer makes for a penny what a scientist makes for a pound! |
11th Jul 2010, 6:08 pm | #584 |
Another Model 8 Mark V, Thorn era unit with part number 5170-211 (bought from University of York, who probably had it from new),
Serial: 00952 8V/5/78 The 15V battery fitted to this one is a BLR154, which is the right length but 15mm in diameter, so there's a plastic moulding to make it stay put (part 5210-064). Doesn't help a lot because it's flat ... |
26th Jul 2010, 11:48 pm | #585 |
A reasonable Model 7 Mk 2 with a few bodged repairs - 450R and 4k5 multiplier resistors incorrect (see components wanted section), most case screws missing and some very poor soldering and chewed up screw heads associated with repairs. The two 1289 batteries had mercifully not leaked, but the holder for the D cell was corroded - now repaired.
Despite all of this, it works well and is probably close to its specified accuracy. The "7" is a very clever meter and I'm looking forward to using a few of its special features. ("Q"). It survived a trip through the post with little more than a jiffy bag wrapped around it and a piece of card over the glass. I'll give AVO the credit for robustness. Ser. 2883-A-167-M What does the "M" signify at the end of the serial number? Leon. |
30th Jul 2010, 7:13 pm | #586 |
My Avo, beast,s..Model 8 Serial no 87300-c-259. And Model 8 Serial No 147686-0-1062. And Model 7 43358-A-753. And Model 8 Serial No 67300-C-259. Military Avo unmarked Serial No wise. Model 8 Mk 1V ??. And Avo Model 8 Serial No 07063 6V/5/77. printed circuit. i have several other Avo,s eg.. Avo Heavy Duty, and Avominor, and Avominor Air Ministry type e Serial no E.4253 1942.n All Avo,s are working....Alan.
31st Jul 2010, 5:20 pm | #587 |
Just aquired an original McAdie avometer serial No. 135998 Trevor |
1st Aug 2010, 6:05 pm | #588 |
Can't resist these at carboots especially for £3.
Avo 8 52821-C-1056 My 2nd Mk I and like the other it seems to be in perfect working order and this one even has batteries. Shame someone has used it as a soldering iron rest which has left a few small marks in the bakelite and 2500V screw terminals. |
1st Aug 2010, 9:22 pm | #589 |
Congratulations, Trevor (I already have it's serial number)
3rd Aug 2010, 2:23 pm | #590 |
Hi - what I've found in the house so far; non 'liberated' so no need for X's
Avo 9 mk II serial no 4-491-166 Avo 8 mk II model B serial no 71599-C-358 Avo 9 mk IV? (front button missing but has 100 and 30 scale - instructions plate on back are for 8 mk IV and 9 mk IV) serial no 1522-1V-969 Avo 7 mk II serial no 5135 -A- 1162 F Avo 8 mk V serial no 39597 8V/11/76 Heavy Duty Avometer serial no 937-1249 More when I can find them. |
5th Aug 2010, 8:32 am | #591 |
Model 8 IV 30846 84/2/71, caught on the way to a skip, complete with case, Avo leads and the croc clip. The croc clip is most useful.
7th Aug 2010, 5:09 am | #592 |
Avo model 8 no 166161-C-1163.
Front panel engraved with SMA ( Snowy Mountains Authority ), E & M ( Electrical and Mechanical division, where my father worked since 1949, but this isn't his), Plant Number 324096. Given to me recently by the guy that taught me half of what I know, alas now he is a very old man. It's in well used condition but functions perfectly. Regards, Joe. Last edited by Darren-UK; 7th Aug 2010 at 8:46 am. Reason: FSK. |
24th Aug 2010, 7:09 pm | #593 |
I have acquired an AVO Model D in wonderful fully working condition.
Serial number is 14571-544. I assume it was made during May 1944. Neil.
5th Sep 2010, 5:21 pm | #594 |
Was just researching the avometer i recently picked up. Having looked through all the posts in this thread i thinks its what you would describe as a dc avometer 13 range (model 2) 1927 - 1936. The plaque on the back states it was made at the Douglas Street factory, so i think that means it's later than 1930. It has a wooden lined battery compatment, which has the number - 1472 stamped into the base, is that the serial number? Nothing on the scale other than TYPE HR 2 and a part no 12159/5, is that the scale part no? But i was a little confused as the inner part of the scale, the red printed part is labeled 10V.A.C, so does this mean it is AC as well? I have added a picture, hope it helps. Picture - http://i979.photobucket.com/albums/a...o/P1010869.jpg Just trying to test it, but probably beyond me. It accurately measured the voltage of a AA battery, but the needle seems to stick occassionaly. Regards Paul |
5th Sep 2010, 7:11 pm | #595 |
Hi Paul
It is indeed a model 2. But its been got at, the scale plate is from a model HR2 which is a much later model with AC. It is well known that model 2 scaleplates had a high risk of the paint flaking. Probably why it has been replaced. Whether or not it still has its original movement is another question. Regards Trevor |
9th Sep 2010, 12:09 pm | #596 |
Just got an Avo 8 Mk5, s/n 93018 8V/7/73
Bit of a haze under the glass/on the mirror - is there a way to clean that or should it be left well alone? Otherwise, it's in very good condition. Cheers
Nicko |
27th Sep 2010, 4:36 pm | #597 |
I have 4 Avo, 3 in working order one with good case but faulty, suitable for spare parts? . Model 8 Mk.4No.1580-1V-960, Model 8 Mk.3 No.11949 Model 8 Mk.5 No.P5720-046. Model 8 Mk.5 N.5270 CH 485.
5th Oct 2010, 6:54 pm | #598 |
I got mine from a boot sale for £5. It's a model 9 mk2 14737 868 which I think makes it 1968. Last edited by Darren-UK; 5th Oct 2010 at 11:13 pm. Reason: FSK. |
12th Oct 2010, 12:21 pm | #599 |
Two more AVO,s
Model 8 S/n 23877-C-454 Model 8 Mk3 S/n 17374 665 Both in working order. Regards Trevor |
25th Oct 2010, 10:20 pm | #600 |
Just purchased another, model 8 mk2 No 2013. c463D.
Mark |
