13th Dec 2018, 8:50 pm | #21 |
Re: Restoring/repairing a triode output valve
To reliably re-fire any remaining getter in the original getter-holder you will indeed need some form of induction-heater.
That assumes there's any getter-material left to re-fire. And that whatever fault has caused the original gettering to have failed is not still there.... TBH I'd be looking more at reworking the amplifier to use non-defective valves. I'm sure a couple of 6L6, KT66, 5B/254M could be engineered in there, either as grid-strapped pseudotriodes or with screens wired to HT as Mr. Sarnoff and friends always intended. Done properly I'd guess it would end up a lot louder than the triodes. |
13th Dec 2018, 8:52 pm | #22 |
Pulsed laser deposition https://en.wikipedia.org/wiki/Pulsed_laser_deposition ?
Small-ish pulsed lasers are fairly readily available and allow you to 'place' energy very precisely without heating the surroundings much at all. There may well be a laser processing job-shop somewhere that would be prepared to have a go. Make sure you're absolutely clear about the hazards though. They blind in an instant. Cheers, GJ
http://www.ampregen.com |
14th Dec 2018, 3:03 am | #23 |
I'm not yet convinced that the valve is actually gassy. Without actually seeing it in action it's hard to tell. If it's just the slight blue tinge seen on the inside of the glass in a darkened room as I mentioned before, then I don't think there's too much to worry about and the problem is more likely to do with the actual heater connection in the base of the valve. On the other hand, if the whole inside of the valve seems to be glowing very blue, and can be seen under normal light, then that is bad news. The last power output valve that I saw doing that was an EL519 which would sometimes flash over as soon as HT was applied and blow the fuse in the unit it was in. Once it had stabilise and had stopped flashing over, it worked to an extent, but the blue glow was all around the internal electrode structure and seemed to light up the entire inside of the valve - now that WAS a gassy valve!
14th Dec 2018, 2:41 pm | #24 |
The grid voltage is not at 0V and can vary up to 50V! Thats surely not good news.
14th Dec 2018, 3:06 pm | #25 |
If that's +50V and the grid leak is not open-circuit then that indicates enormous grid current corresponding to very serious levels of gas in the valve. Normally I start to suck my teeth about grid current if it approaches a microamp and if I remember rightly the maximum of the Gas range on my AVO CT-160 is 5 microamps (if you know the grid leak resistance you can work out what positive grid voltage that corresponds to).
Cheers, GJ
14th Dec 2018, 3:15 pm | #26 |
That doesn't sound good at all.
The thing I can't understand about this is what are 'CV' type numbered valves doing in this amplifier? I suspect that sometime, perhaps recently, with all the talk of the value of the original valves, that someone has removed the original valves and sold them in exchange for a couple of 'supposed working well enough for a radiogram' type valves that are not worth very much, but unfortunately, one of them is a duffer - this could have happened before you were asked to look at the radiogram. I think some inquiries need to be made regarding its recent history, that's if it's the same gram as I think it is. Did the dust level on those valves match the level of dust on the rest of the innards of the gram and its chassis? |
14th Dec 2018, 11:05 pm | #27 |
Techman brings up a very valid and interesting point. The original output valves as marked on the chassis are PP3/250 so it has been 'got at' but with no other sign of tampering. The driver valves are original as is the rectifier valve as is all the valves on the radio chassis.
Given that this probably dates from the late 40's to very early 1950's it would probably have been fitted with a 78 only deck, something like a Garrard RC60 or RC70. What I found in there was a BSR UA6! These valves may well have been changed a long time a go. To make matters slightly more difficult, I'm repairing this for a 3rd party who will not be the end user. |
14th Dec 2018, 11:46 pm | #28 |
So that brings up the question of what the owner wants. If he's of the "It must be triodes" view, then he's into big bucks territory. The audiophools have created high priced demand for all power triodes, so any exact, near or far equivalents are going to be pricy.
If his view is "I just want it working" then that opens the door to triode-strapped beam tetrodes. I'm concerned about how reliable it would be if that existing valve was somehow brought back from the dead. I wouldn't want it to impact your reputation, Michael. David
15th Dec 2018, 10:45 pm | #29 |
The thing is, its not quite so easy to modify for triode strapped beam tetrodes is that it requires quite a few modifications.
PX4 et all have a 4V heater, beam tetrodes and pentodes use 6.3V heater. The existing heaters have to be modified so that they are disconnected from the triodes. A new transformer would have to be fitted, the valve bases would have to be changed, the cathode circuits would have to be somewhat reworked. After carrying out all this work, it might be cheaper and easier to find a replacement valve. |
15th Dec 2018, 10:57 pm | #30 |
There are quite a few 4V tetrodes and pentodes. Some are directly heated and if you could find one with a loose base you could fit a B4 base and triode-strap inside it. Unfortunately most of the relatively high audio power ones take 2A from the heater supply rather than 1A and might overload the 'gram's mains transformer. I don't know if PP4s ever show up (apparently equivalent to Mullard PM24M http://www.r-type.org/exhib/aad0272.htm) or whether they might work anything like a PX4 if triode-strapped.
Cheers, GJ
http://www.ampregen.com Last edited by GrimJosef; 15th Dec 2018 at 11:23 pm. |
18th Dec 2018, 7:18 am | #31 |
Not being familiar with the diameter of your tube, but you might try to find a neon sign shop nearby, and ask them to use their induction heater on it to re-heat the tube and re-flash it.
Typically, all the gettering material does not get used up in the factory flashing process. |
18th Dec 2018, 1:52 pm | #32 |
If you search eBay for induction heater, there are several of varying powers. You'd need to experiment with the coil, which means it's probably not a quick fix, and the cheapies may not be powerful enough...
