12th Aug 2020, 3:52 pm | #1 |
Much Magic Smoke - But Amp still playing - NAD 3030
While listening to music this afternoon I heard a little crackling sound behind me (I love crackling, but not this kind).
A plume of smoke was curling from the NAD amp - music still merrily playing. I isolated the supply pronto. I've ripped the cover off and was about to post photos of the fire damage - but there isn't any visible. I've check the board, expecting a fried capacitor or resistor.... nothing. The transformer seems to smell the worst, but I'm not sure it is the source of the smoke.... not a lot to go on ladies and gents. SEAN
There are only 10 types of people, those who understand the binary system, and those who don't. |
12th Aug 2020, 4:15 pm | #2 |
Re: Much Magic Smoke - But Amp still playing - NAD 3030
The most common cause of this sort of thing - hopefully - is the snubber capacitor across the mains with the most common offender being the RIFA semi-transparent ones. However I don't think your NAD uses them, though I may be wrong. If it does, then there are many threads on the forum talking about them - with good reason!
I'm afraid the only way to determine what's going on is to power up with one hand on the switch. Leave the speakers disconnected for this just in case. Did you notice any degradation in the music? Inspect the various resistors in the output stage feed - these can cook, but usually don't emit all that much smoke and the affected channel dies. |
12th Aug 2020, 4:21 pm | #3 |
As Glyn states, always suspect any Rifa or Wima capacitor across the mains or a Schaffner mains filter, especially if the amp was still playing. Hopefully it's not the transformer.
Mike |
12th Aug 2020, 4:43 pm | #4 |
Looking at the schematic it shows 2 capacitors, one each across the switched live and neutral connections at the On/Off switch. Assume these are some sort of spark suppressor, they are identified as 4700P, which I assume is 4,700pF which seems quite a low value in this application.
Cannot see them listed in the parts list. If one or both have burnt up and gone open circuit then the amp will still work as normal. David |
12th Aug 2020, 4:44 pm | #5 |
This is the mains input circuitry as shown in my copy the service manual. If it's correct (and if I've understood it correctly) there should be no voltage across the capacitor when the amplifier is switched on.
Edit - Crossed with David. It seems there may be different versions of the circuit. Hugh Last edited by Stockden; 12th Aug 2020 at 4:48 pm. Reason: spelling! |
12th Aug 2020, 4:57 pm | #6 |
Yes agreed no voltage across the capacitors once switched fully on, so theoretically should not go up in smoke while running, the 3020 circuit is slightly different.
Looking elsewhere 4,700pF disc ceramics are sometimes used as suppressors. David |
12th Aug 2020, 5:21 pm | #7 |
They're 4700pF, 400VAC ceramics in mine (NAD 3030), one across the on/off switch 'live', one across the switch 'neutral', and they're close to an inch across - so, although I doubt it, it should be pretty easy to see if they're burnt.
Alan |
12th Aug 2020, 5:23 pm | #8 |
Happened to mine years ago. Everything carried on working, I couldn't see any signs of distress, so I just ignored it. That amp is in line for a major overhaul so I'll investigate it further then.
12th Aug 2020, 5:44 pm | #9 | |
I have attached a photo the component which is EXACTLY what you said it was and even semi-transparent. Thank the lord it was not the transformer! I'll replace that cap with another x-rated one - thanks again: Now, onto a related issue - the on/off switch has never worked and now I have it 'prone' I should ideally replace it. Any ideas where one would get a switch like that photographed please . . a big ask on a hot day - but this is why the Forum works!!! SEAN Thanks in advance - and to all that said Rifa!
12th Aug 2020, 5:46 pm | #10 |
Sounds like a problem I had with a Cambridge P50 which I repaired. I was listening to it when there was an almighty bang, loads of smoke and what smelled like a burning transformer. Turned out that a Rifa connected in series with a resistor across the mains had gone short-circuit vapourising the resistor.
The amp carried on working once the 3 fuse in the mains plug was replaced.
12th Aug 2020, 6:16 pm | #11 |
The switch is probably clagged-up with old dried-out contact-grease or similar: rather than replacing it you have nothing to lose by buying a can of 'brake cleaner' spray from the local car-parts place, putting the switch in a small jam-jar, squirting-in a load of the cleaner then screwing the lid on and leaving for a few days so the cleaner can do its thing on the cruddy grease.
Then take the switch out and use more cleaner squirted directly into any openings/apertures you can see on the switch, then 'work' it vigorously on-and-off, then more squirting! it takes a lot to dislodge decades of dust that have settled into the grease. |
12th Aug 2020, 6:58 pm | #12 | ||
DAVID |
12th Aug 2020, 8:52 pm | #13 |
12th Aug 2020, 9:49 pm | #14 | |
My NAD cassette deck died some months ago (complex issues in the transport mechanism which hours of effort failed to resolve), but I managed to substitute that with a Harmon Kardon TD392, bought via ebay but from a local seller. B
13th Aug 2020, 7:51 am | #15 | |
I will treat the switch, but it is broken at the front (post itself is snapped) and it is currently broken in the 'on' position. I may get unlucky and get it to move from 'on' to permanently 'off'! Does the switch look generic to you people? SEAN
13th Aug 2020, 9:53 am | #16 |
I'll have a look if I have something similar.
If you have repaired NADs you'll know the schematic serves as a general guide as the unit you're working on will be significantly different! I'll claim my prize later... |
13th Aug 2020, 10:02 am | #17 |
Hi Sean.
I have a switch which looks like that. It looks used but you are welcome to it FOC. I assume you have the knob. If you PM me with your details I'll pop it in the post. Regards Peter. |
13th Aug 2020, 10:03 am | #18 |
Not sure on the exact details for the 3030 switch, but this may be close:
https://www.rapidonline.com/Power-PC...efe5667219c31a |
13th Aug 2020, 10:11 am | #19 |
Hi Sean, I have the 2 push switches shown below. I guess size is important so I included the ruler. End-on the max height of the blue-tipped switch is 24mm; the hole spacing on the front bracket is 18mm. The other one measures height of the black bracket 15mm, white part 8mm (including contacts 17mm). Mounting holes 23mm. Are either of these any use? Cheers, Jerry
13th Aug 2020, 10:29 am | #20 |
The 2 green gremlins are capacitors and the 1K suggests that they are 1000pf or 0.001uf if you prefer the uf value.
