11th Aug 2020, 1:40 pm | #1 |
Philips 205 record player
Hi
I have inherited a Philips 205 record player (wooden casing, brown plastic lid type). It has one outgoing socket for speaker connections with a round plug and 5 male ends in a half moon. Inside are white, blue, green and red wires. How do I connect to a speaker? The original owners said they didn’t have an amp but no longer had the speaker they used. Thoughts? |
11th Aug 2020, 2:44 pm | #2 |
Re: Philips 205 record player
You seem to be describing a 5 pin DIN socket. It's highly unlikely that this would be used to connect speakers. It would originally have been used to connect a tape recorder or cassette deck, though you could also use it to connect an external amplifier.
The speakers are likely to use 2 pin DIN speaker plugs. https://en.wikipedia.org/wiki/DIN_connector [Later] I've checked and this is actually a record deck, not a record player. It needs an external amplifier and cannot drive speakers directly. https://www.radiomuseum.org/r/philips_ga205ga_20.html |
11th Aug 2020, 4:06 pm | #3 |
Philips made quite a few incarnations of that style of TT in the 70s, and they are nice players. But it might need some work if it has not been used for years. Do you not have any audio equipment you could connect to?
'....don't go mistaking Paradise for that home across the road!' (Bob Dylan) |
11th Aug 2020, 4:16 pm | #4 |
I believe it has a ceramic cartridge, but I don't know if it has any form of preamp inside.
11th Aug 2020, 10:03 pm | #5 |
Hi, no it doesn't have a preamp. It's a very nice semi automatic TT. There's a YouTube vid of a demo with a Philips amp. Just go on YT and type in search box 'Philips 205'
12th Aug 2020, 12:12 am | #6 |
It might have a phono pre-amp - there were ceramic and MM cartridge options and a little compartment to pop in the pre if the owner wanted to buy one.
