Old 3rd Jun 2020, 11:28 am   #41
6.3volts
6.3volts's Avatar
Default Re: Pye 350/C "All Electric Three" 1929
Originally Posted by PJL View Post
You are dealing with valves that don't like much of a load so higher primary inductance will give better LF response and then if you want some gain you need to wind 4 times that amount for the secondary. I also rewind these by hand and 12000 turns for a secondary is not unheard of.
Thanks for your input. I see your point and may revisit the transformer in the future if my results are poor.
Jonathan.
6.3volts is offline
Old 10th Aug 2020, 3:42 pm   #42
6.3volts
6.3volts's Avatar
Some time later---
The set is working well, my BBC headphones are quite loud and the set pulls in such stations as are available in my rural area. LW is very good and the sound quality in the phones is excellent. I very quickly learned to take the phones off before operating the wavechange switch as I am rewarded with a VERY loud crack which leaves me wondering when I will be able to hear properly again.
The case came up well and needed stripping and very little sanding. The wood is hard and close grained and took an easy shine. The back was missing (of course) and by luck I found some very clear pics online. By careful measurement and some guesswork I arrived at a plan using imperial sizes and I am very pleased with the result. My attempts at staining are more ok than good but at a distance and in poor light it looks ok.
The finish on the front panel is primer and a felt pen. Hopefully to be improved in time.
I thought it might help if I added some notes and numbers to my copy of R Thornton's 2004 "All Electric Three" in case this is of interest to any other owners. I hope to do this when time permits and then I believe this set will be done. I propose to post my notes (photos of my printout of Mr Thornton's original with my additions written on them) here if that is within the forum rules and they will be freely available without restrictions on their use.
Regards to all Jonathan.
ID:	213153   Click image for larger version
ID:	213154   Click image for larger version
ID:	213155   Click image for larger version
6.3volts is offline
Old 10th Aug 2020, 4:26 pm   #43
vinrads
Looks good to me I never got round to making a back for mine , another job on the list, do you intend to paint the front brown crackle finish at some later date , I did mine with black crackle and then over painted it brown looks ok ,I have yet to do the lettering . Mick.
vinrads is offline
Old 10th Aug 2020, 9:08 pm   #44
6.3volts
6.3volts's Avatar
Mick, I hadn't thought of crackle, but that's a good idea. My main worry is that having left it in primer I might find the job slipping to the back of the queue.
Lettering was never my strong point so I'm wondering how to do that on a crackle finish.
Jonathan.
6.3volts is offline
