22nd Feb 2021, 5:49 pm | #21 |
Re: Output Valve bias meter? how to wire in correctly?
David: Thanks for your post 19.
As for a metal zero-adjusting screw, hazard arising as a consequence, that is something I've never considered. As I sit here and write this, that is a consideration that I do not know to be applicable to my stock of meters: something I will have to check-out and bear in mind from this moment on. Al. |
23rd Feb 2021, 10:52 am | #22 |
The earthing of the filament supplies puzzles me a bit. Both the supply for the 71-A filaments and the 6F5 filaments are earthed. Probably this does not create big problems anyway because of the relative high value of the two 50 Ohm resistors. But still I wonder what will be going on current-wise.
The schematic from post #17: https://www.vintage-radio.net/forum/...7&d=1613918787 Addition: If this is too much off-topic, just ignore this post.
Robert Last edited by Robert Gribnau; 23rd Feb 2021 at 11:13 am. Reason: Addition |
24th Feb 2021, 6:09 pm | #23 | |
I know that the valves on the left are voltage regulators but the center black coated one is? The large one on the right is maybe a 807? Dave, USradcoll1 interested! |
25th Feb 2021, 10:58 am | #24 |
To be honest Dave I can't recall...I asked at the time on the forum (several years ago) and it was deemed to most probably be a power supply from perhaps an old telephone exchange. That was as far as we got...there were a couple of variable pots and lots of tappings....one was an 807 and as you say voltage regulators x 2 ....I still have all the spare parts in the loft ...one day the mammoth 400-0-400v power TX will power maybe a 300B amp or something similar as it has 6.3/5 and 4 volt heater taps. It was a v cheap ebay purchase.
Best Mike |
25th Feb 2021, 1:24 pm | #25 | |
I found out about it as a schoolkid when I asked about the perspex plates mounted on extensions of the screws holding classic round meters in the panels of a walloping big broadcast transmitter. Our guide knew the reason and explained it well. I think he was rather pleased to get asked. David
25th Feb 2021, 1:28 pm | #26 |
The shaft of the meter set zero pot in the HRO receiver can give a kick, amongst other adjustments.
Lawrence. |
25th Feb 2021, 6:26 pm | #27 | |
Fully knowing this is slightly OOT, but it's worth looking into. I'd be lost without the excellent Heath schematic website. Dave, USradcoll1, retired but, seldom bored. |
