14th Sep 2021, 2:13 pm | #21 | |
Re: Valve testers & 'soak' testing.
I did actually test that out - there can be a difference - so likely depends on cause.
I did actually test that out - there can be a difference - so likely depends on cause. I did actually test that out - there can be a difference - so likely depends on cause. Quote:
The 5U4 I tested are directly heated cathode, so likely some difference to say a GZ3x, although worth reading the linked forum (Figure 33 hyperlink) as nevetslab was measuring anode currents in 5AR4. |
