4th Sep 2007, 9:44 am | #1 |
oscillating amp
Hi Everone,
I built a stereo amp last year and it works very well, it has ECC81 phase splitter and 6v6 push-pull output. My problem is when you turn the amp off its as if someone is rapidly connecting and disconecting the control grids to earth! and so the audio is modulated if you like. It has done tihis since I built it. How can I stop it? It doesn't affect the operation of the amp, it is just annoying! Many thanks. Lee
Lee |
4th Sep 2007, 9:46 am | #2 |
Re: oscillating amp
I know in the schematic it quotes ECC83's. I changed the valves but haven't updated the drawing yet.
Thanks Lee
Lee |
4th Sep 2007, 2:52 pm | #3 |
Re: oscillating amp
Sounds like unwanted positive feedback as the HT fades away.
I suggest you try incorporating some HT decoupling between the phase invertor stage and the 6V6 screen grids. Use something like 10k ohms in series with the HT and 22uF to ground. Ron |
4th Sep 2007, 5:11 pm | #4 |
Re: oscillating amp
I don't think that this is related to your problem - but I've got to enquire - why such a low input impedance (68R) for an audio amp?
(Thinks: I might be missing something obvious here; not unusual ) Al / Skywave. |
4th Sep 2007, 5:18 pm | #5 |
Re: oscillating amp
Seems like a remarkable lack of HT decoupling in that cct. to me.
I'd try installing an R/C decoupling network between the common junction of the two 150K resistors (triode anode loads) and common HT. Something like 22k and 8uF as a "starting guess". Al / Skywave. |
4th Sep 2007, 9:41 pm | #6 |
Re: oscillating amp
OK, so what I need to do is put a resistance of around 22k in the HT+ supply to the phase splitter and then add 8uf of smoothing to the "lower voltage end" of the 22k resistor?
That would seem to make very good sense actually I'll try it tomorrow and report back. Many thanks Lee
Lee |
4th Sep 2007, 9:51 pm | #7 |
Re: oscillating amp
Hi Al,
There is a 68R resistor across the inputs because when the amp was built it was too sensitive ( I don't have a pre-amp built yet so am using the headphone out of an intergrated amp at the moment) and I tried negative feedback from the output tranny to calm things down but it severely compromised the audio quality so decided against it, it is a bit of a bodge really and I don't intend on leaving it that way permanently as it is an impeadance mismatch. I just need to work the grey matter until I come up with something different! Cheers Lee
Lee |
5th Sep 2007, 10:42 am | #8 |
Re: oscillating amp
Hello Ron & Al,
Good news, The amp does not oscillate anymore! I took your good advice and added some decoupling between the splitter and power stages and also stuck 5600puffs of decoupling from the 6v6 screens to earth and it now just fades gracefully when turned off New drawing attatched for those interested. Thanks again. Lee
Lee |
5th Sep 2007, 11:03 am | #9 |
Re: oscillating amp
Al,
I have attatched a copy of the schematic components I have drawn that I use with paint. Hopefully you can save the image and then open it with paint and design your own circuits by copying and pasting. Sorry mods, I know it's OT but I can't seem to find a way of sending an attatchment in a PM. Cheers Lee
Lee |
5th Sep 2007, 6:26 pm | #10 |
Re: oscillating amp
Hi Lee, nice to fine another person who advocates using Paint,it's all I use now I have a good solid database of components. Your circuit has a misplace.
The anode load centre points of the phase splitters do not go to the same place, I have amended your circuit (see attached), assuming that you want both channels to be fed from the screen supplies of the output bottles. Incidentally, I draw in bitmaps first then if I want a smaller file, I save it as a TIFF, it seems to pick up less of a speckled background that you get with jpegs. Regards Les
5th Sep 2007, 6:44 pm | #11 | |
Re: oscillating amp
I have just done that : it'll probably save me hours! Al / Skywave. |
6th Sep 2007, 9:25 am | #12 |
Re: oscillating amp
Goodmorning Les,
Thanks for the pointer on the mistake on the schematic, below is how it is supposed to be wired, thanks for the tip on using TIFF files, I will try it. All the best Lee
Lee |
6th Sep 2007, 11:14 am | #13 | |
Re: oscillating amp
7th Sep 2007, 8:54 am | #14 |
Re: oscillating amp
There is another slight (mistake?) as well - the two 3M3 grid leaks on the ECC 83 need a "blob" to connect them to the junction of the cathode resistors or they look as if they are not connected.
I agree with the comments regarding M$ Paint - after trying various proprietary cct drawing freeware I found that it never did what I wanted. I follow Les and Lee's methods more or less exactly.
Mike. |
7th Sep 2007, 9:56 pm | #15 | |
Re: oscillating amp
Surely, the full HT from the PSU should feed the 1 k-ohm screen grid resistors direct, and the same PSU HT point should also feed the 22 k-ohm resistor, the other side of which should be connected to the 47uF cap. and the four 150 k-ohm anode loads? That way, the triode anodes HT source only is decoupled by the 22 k-ohm and the 47uF - which is not what is happening as its drawn - but is what is needed. As it stands, I can see that at switch-off, the time-constants on the PSU rails - and including the reduced screen voltage - are likely to put the amp. into a transitionary unstable state as the HT gradually falls. (I assume that this is not what is required ) Also, as it stands, you've got reduced HT to the screen grids (22 k-ohm R) - limiting the final power O/P. It's usual to run the screen grids at full (or very nearly full) HT. Al / Skywave. Last edited by Skywave; 7th Sep 2007 at 10:06 pm. |
7th Sep 2007, 10:17 pm | #16 | |
Re: oscillating amp
9th Sep 2007, 4:25 pm | #17 | |
Re: oscillating (?) amp
Kind regards, Darius |
10th Sep 2007, 3:23 pm | #18 |
Re: oscillating amp
Aside from the matter of decoupling, which I fully agree with, I would also propose that your phase inverter is rather unbalanced.
This is liable to generate quite a lot of 2nd harmonic, which, although not unpleasant, is still more than necessary and isn't really to be expected of a hifi amp. I would suggest reducing the anode resistor of each of the input triodes by around 15% (say 130k to 140k). The 3M3 grid leaks are also unecessarily large, 470k would be quite sufficient, greatly reducing noise. |
18th Dec 2007, 6:57 pm | #19 |
Re: oscillating amp
There is a severe lack of negative feedback as well! It is usual for amps' of this kind to take a small amount of fedback from the output transformer and send it back to the pre-amp. That would probably do much to tame it and would also increase the frequency response.
