Old 15th Feb 2019, 8:36 pm   #1
Vintage_RC
Vintage_RC's Avatar
Default Pye Q4 wavechange switch problem
I have a Pye Q4 lift up lid early transistor portable which works on MW but not on LW. I decided to investigate the problem today, I used another set to listen to the local oscillator (LO). It was evident that when I changed from MW to LW the LO didn't change frequency so suspicion immediately fell on the wave change (WC) switch. A look at the circuit and the wiring showed the contacts where the problem might be and a poke on the suspect contact with an insulated tool made the LW work. I have attached a photo of the WC switch with a ring around the problem contact. The problem is how do I close the contact gap above and below without a messy dismantling of the whole wafer switch assembly? Another point not helping is that mating face that the contacts should touch does not seem to project as far out as it should when compared with other parts of the switch assembly.
Name:	Pye Q4 WC_LWs.jpg
Alan G6PUB, BVWS
Vintage_RC is offline
Old 15th Feb 2019, 9:42 pm   #2
cathoderay57
Default Re: Pye Q4 wavechange switch problem
Hi Alan, statement of the blooming obvious perhaps but have you tried a squirt of switch cleaner? Since the contacts are easy to get at you might try squirting some onto a cotton bud and gently wiping the contacts. Looks like there is a lot of oxidation there. It isn't usually a good idea to start bending the contacts as that can end in irreparable damage to the switch. Cheers, Jerry
cathoderay57 is offline
Old 15th Feb 2019, 9:52 pm   #3
PaulR
PaulR's Avatar
I have recently tried a can of WD40 - no not the original stuff but quick drying contact cleaner and so far it works really well.
Paul
PaulR is offline
Old 15th Feb 2019, 11:24 pm   #4
Vintage_RC
Vintage_RC's Avatar
Yes I had tried a quick squirt of Electrolube to no effect. Regarding your commenting about bending the contacts, on close examination it looks like someone has at some stage in the past done just that. When I gently push down on the contact there is a small but perceptible movement suggesting there is a physical gap. This is looking like a tricky one to solve.
Alan G6PUB, BVWS
Old 16th Feb 2019, 1:09 am   #5
Ambientnoise
It is indeed sometimes possible to increase the bend angle on the contact fingers, using tweezers or pointed pliers. Go easy, using a prod of some sort to hold the rivet side of the bend flat. Check for loose rivets etc first. Bending does not work if the metal has lost its spring and there is a risk of breakage but I have had reasonable success.
Ken
Ambientnoise is online now
Old 16th Feb 2019, 7:16 am   #6
ajgriff
ajgriff's Avatar
Personally I wouldn't hesitate to try bending the contact and have done so successfully on a number of occasions. After all, how else do you deal with a bespoke wafer switch in a long obsolete piece of equipment? Also, there's not much to lose since the switch isn't working anyway. I would slip a darning needle under the contact arm and apply light pressure to the contact itself. Loose rivets can often be tightened with a small pair of pliers or even a carefully applied blob of superglue if access is a problem.
Alan
ajgriff is offline
Old 16th Feb 2019, 10:34 am   #7
cathoderay57
Replacement wafer switches are available but you'd no doubt have to figure out how to wire it and cut the shaft to fit etc. There's a 6-pole 2-way at Farnell here; that's just the contact set - the shaft and carrier assembly is extra so when you add it up it's fairly expensive. https://uk.farnell.com/nsf-controls/...-switch-wafers . Good luck
Old 16th Feb 2019, 11:13 am   #8
Nanozeugma
Nanozeugma's Avatar
Location: London, UK. Bury, Lancashire quite regularly :)
Gentle scrubbing with a fibreglass pencil followed by a few dabs of DeOxit.
Thermionic Emission, warms the cockles of your tubes.
Nanozeugma is offline
Old 16th Feb 2019, 6:21 pm   #9
Vintage_RC
Vintage_RC's Avatar
As I intimated earlier the problem is not one of cleaning but that the contacts are not touching the wiper. I have come up with a simple solution using part of a bent pin. OK it's a bit crude but it works. See photo.
Name:	Pye Q4 WC fix_s.jpg
Alan G6PUB, BVWS
