Old 3rd Feb 2019, 6:27 pm   #1
barrywebb
Default Akai 4000DS rubber spool holders
Hi just having problems with the two rubber bungs that hold the spools on well there not holding.
Just wondering if anyone has had this problem and what to do to repair them i have just ordered some Rubber Renew just to see if that will soften up the rubber if anyone has any ideas i would love to hear them.
Barry.
barrywebb is offline
Old 3rd Feb 2019, 7:52 pm   #2
vidjoman
Default Re: Akai 4000DS rubber spool holders
Back in the 70’s we just used rubber grommets.
vidjoman is offline
Old 4th Feb 2019, 1:19 pm   #3
Skywave
Arrow Re: Akai 4000DS rubber spool holders
I realise that this suggestion is very inelegant, but when I owned an Akai 4000DS that had that problem, I resorted to spring-loaded washing line pegs! The wooden ones were best; plastic ones kept falling off. (All down to a matter of friction, of course).
Al.
Skywave is offline
Old 4th Feb 2019, 1:53 pm   #4
TIMTAPE
A round rubber door stop, the one with a hole in the middle for attaching to a floor or wall. It's been a long time since I used them for this. They may need the hole slightly enlarged.
TIMTAPE is offline
Old 4th Feb 2019, 3:02 pm   #5
8 Tracker
8 Tracker's Avatar
If you still have the originals and from your post it looks like you do, a cable tie wrapped around the top part and then pulled tight with pliers worked well for me. If you use black ties, you can't really see it, either.
Mark.
8 Tracker is offline
Old 8th Mar 2019, 9:23 pm   #6
Gordondav54
You should be able to improve the tightness of the existing rubber things by squeezing them in a bit. I have used strong 'steel split key rings' for this purpose. Available eBay. It depends on the size and shape of the rubbers but you need to find rings that are a tight fit and file a slight groove in the rubber first to locate the ring. Alternatively a stout O ring glued on with superglue might do the job.
Gordondav54 is offline
