Old 19th Jan 2019, 8:49 pm   #1
JanWra1
Default AR88 screws thread again
H i guys,
I searched for info abt the threads on the 4 screw holding the receiver to the cabinet. Found a thread from abt 2012 that stated that the thread is UNF 12-24 and Henry Rogers stated the same on his website.
However on mine the threads are UNF 12-32 and the cabinet is manufactured by Am. Cabinet Hardware Corp, Rockford Ill. (Pic 1 & 2)
Was the cabinet produced by more than on manufacturer and if so did they use different threads? In addition did they use different kind of screws?
On mine the screws are chrome plated. (Pic 3)
Appreciate your comments
Jan
Name:	AR88 cabinet.jpg
ID:	176745   Click image for larger version
Name:	AR88 cabinet manufacturer.jpg
ID:	176746   Click image for larger version
Name:	AR88 cabinet screw.jpg
JanWra1 is offline
Old 19th Jan 2019, 9:31 pm   #2
Default Re: AR88 screws thread again
Cabinet Hardware sounds like that is the maker of the catch, not necessarily the maker of the cabinet.
Radio Wrangler is offline
Old 19th Jan 2019, 9:52 pm   #3
The AR88 cases I've used have all had "cage nuts" - these are available in various styles and easily spring out and re-insert to match the threads of the screws you want to have visible on the front.
See https://www.networkcomputing.com/dat...67960/page/0/1
The only difference from this is the "Hubbell rack" screw/nut that you find in data-centres/phone-exchanges - but these are #12-24 x 5/8-inch on 23-inch centres and won't handle your AR88 without some additional infrastructure.
Old 20th Jan 2019, 12:00 pm   #4
JanWra1
Thanks your comments which points out another difference in my case: There are no cage nuts but small Angle irons welded on the inside and drilled and threaded for 12-32. Does this give you any further clues?
Re American Cabinet hardware: Seems David is right abt this as found a website that gives the entire story of this company and seems like they only made stuff like hinges and other stuff for the cabinets.
Jan
JanWra1 is offline
Old 28th Feb 2019, 6:38 pm   #5
usradcoll1
That #12 hardware was never that common, even in the US. It seemed to be used only on equipment built for the US Government.
You'd almost swear that there would be something closer in the metric range of hardware.
Dave, usradcoll1.
usradcoll1 is offline
Old 28th Feb 2019, 6:48 pm   #6
barrymagrec
My Zeus book gives 12-24 as #12 ANC but 12-32 is too fine for #12 ANF - possibly there was an ANEF thread just as there is now UNEF thread.
barrymagrec is offline
Old 1st Mar 2019, 7:52 am   #7
John M0GLN
John M0GLN's Avatar
The 'Machinery's Screw Thread Book' does list both a No12 -32 ANEF thread and a No12-32 UNEF American thread, very slight differences.
John M0GLN is online now
Old 1st Mar 2019, 11:30 pm   #8
emeritus
Here's some extracts dealing with US screw threads from the roughly contemporaneous 1942 edition of "Machinery's Handbook".
It can be seen that the present UNC, UNF and UNEF ranges generally correspond with the S.A.E. NC, NF and EF standards. While 12-32 existed, at that time it was not part of the S.A.E. EF (UNEF) series, but was instead in the S.A.E. special pitch series.
emeritus is offline
Old 2nd Mar 2019, 3:15 am   #9
usradcoll1
Thanks! I loaded in the "Documents" file.
