Old 9th Oct 2018, 10:56 pm   #41
julie_m
Default Re: Pilot Little Maestro Pilot Lamp Conversion
The problem with using X capacitors as voltage droppers is the self-healing and consequent loss of capacitance. Every switch-on surge (a cold valve heater, or a discharged capacitor, is almost a dead short circuit) tends to weaken the capacitor a bit until eventually there is insufficient power available and the circuit begins to misbehave, requiring replacement of the capacitor.
The company I used to work for did some tests and found it was better just to use a standard 400 or 630V capacitor, with a fusible resistor to limit the switch-on surge.
Julie {formerly known AJS_Derby}
julie_m is offline   Reply With Quote
Old 10th Oct 2018, 10:43 pm   #42
Sideband
Sideband's Avatar
What's happened to Kings? We still don't know for sure what the correct valve line-up is.
'Can we have everything turned up louder than everything else'? Ian Gillan...Deep Purple
Old 11th Oct 2018, 3:25 am   #43
usradcoll1
The correct valve line-up was specified in entry #16.
I'm surprised that the # 21 post was so incorrect! I'm rather familiar with this valve line-up.
It seems that Brimar was the main supplier of the US type valves used in the British built radios.
This really was an informative and interesting thread!
usradcoll1 is offline   Reply With Quote
