Old 20th Feb 2019, 12:26 pm   #21
jamesinnewcastl
jamesinnewcastl's Avatar
Default Re: Waxy Capacitors - what did they look like when new?
Hi Andy - good point, I'll make sure to look at that. The HT is only 120V for this system so relatively low.
I think I have solved my potentiometer dilemma. If I can fit them inside the body, a couple of resistors from the wiper to each end will enable me to reduce the resistance at the cost of a slightly S-shaped volts/rotation curve. This would not present a problem in this application as the pots are just presets with no scale to fit against.
James
jamesinnewcastl is offline
Old 26th Feb 2019, 11:46 pm   #22
jamesinnewcastl
Hi All
First new 'waxy' off the production line - I think it looks quite good! It looks a little darker in real life, added a second pic which is more like it the colours are more saturated.
The C10 label was on the original. The leads are only solder at the moment as I don't actually have a cap to go in it!
James
ID:	179096   Click image for larger version
Name:	new cap - Copy.jpg
