Hints, Tips and Solutions (Do NOT post requests for help here) If you have any useful general hints and tips for vintage technology repair and restoration, please share them here. PLEASE DO NOT POST REQUESTS FOR HELP HERE! |
31st Jan 2018, 9:13 pm | #1 |
SMD Parts storage solution.
Hi all,
I’ve come up with a reasonable solution for storing SMD parts, may be useful for others. You will need a 4 litre “Really Useful Box” and two of the insert trays, I got mine from the local Hobbycraft and also some “3ML Plastic Pot Clear Empty screw top Jar/Pot glitter nail art beads crafts Kit” - these were from eBay at £3.39 delivered from a UK seller for a quantity of 50. Hope this helps anyone looking for a solution to storage of SMD or other small items. Kev |
31st Jan 2018, 9:25 pm | #2 |
Re: SMD Parts storage solution.
That’s a really good idea. Thanks for sharing. Certainly takes up a lot less room than my current solution of bagged cut tape.
31st Jan 2018, 11:51 pm | #3 |
that sounds interesting, never seen those little glitter pots before..at least not empty ones
My current DIY smt solution is plastic screw-top test tubes with the code and part number written on the top. The tubes will accept cut tape about 4-5in long and I've made a foam insert for a case by drilling the test tube holes with a piece of 15mm copper water pipe held in the pillar drill. Your idea sounds somewhat more 'ready to use'.
Kevin |
1st Feb 2018, 12:18 am | #4 |
Just ordered my glitter pots 3 and 5 ml size. At the present I'm using sample tubes (new unused) this works well as the rapid electronics and farnell labels peel off the reels and stick on to the sample tubes. I now need to print small labels to fit the new pots.
Bob.
Bob, BVWS member |
1st Feb 2018, 1:35 am | #5 |
I have recently been using Aldi hobby boxes and also those wall mounted chests of small drawers. There were some of the plastic bins wall hangers in stock today.
2nd Feb 2018, 12:29 am | #6 |
I wished those were available here in the States. That looks like the bee's knees for storing those SMT parts. Great idea!
15th Mar 2018, 8:31 am | #7 |
I finally found the little containers here locally at The Dollar Store, for (Surprise!) 10 for a dollar.
They do not come with a storage box, but the store also had small boxes they fit in quite nicely, again for a buck. Now to try to figure out how to fit all the big tape reels of the SMT parts into the itty bitty containers. LOL |
