Old 15th May 2012, 12:05 pm   #1
PJC58-Hythe
PJC58-Hythe's Avatar
Default Philips Philetta - B2D03A
I saw this little set at the NVCF and just had to have it! This has to be one of the most difficults sets to work on due to it's compact nature. The set is only 11"W x 7"H x 7"D but covers LW, MW SW and VHF and has input for an external audio source, so I was hoping that I didn't need to do too much work as it is incredibly difficult to get to any of the components!
On initial checking the the flat selenium rectifier was not working and the smoothing capacitor was very 'leaky', the mains transformer seemed to be OK fortunately. Becuase of the space restraints in this set I decided to strip out the innards from the smoothing capacitor and inserted 2 x 47uF 400V devices inside the original can (an excellent fit allowing just enough room for the wires), I then connected them to the existing tags and put the bottom back on. I stripped out the disks from inside the recifier casing and put 4 x 1N4007 diodes inside and put the case back on. The switches were given a good dose of switch cleaner and the hardened grease removed from the VHF tuning capacitor bearing.
Carefully powing it up I measured the voltages and all seemed well, stations were coming in on all bands except LW. This turned out to be a broken connection from the LW coil on the ferrite rod antenna. That was all I needed to do to get it working, as the chassis and case were extremely clean there was no need to clean these.
What a simple resoration!
Name:	Philetta Front.jpg
ID:	66638   Click image for larger version
Peter - M0HYT - BVWS Member - GQRP Club
http://www.retroworkshop.co.uk
PJC58-Hythe is offline
Old 15th May 2012, 12:20 pm   #2
SeanStevens
SeanStevens's Avatar
Default Re: Philips Philetta - B2D03A
What a gorgeous radio and it does all waves.
I must get one, well done.
SEAN
There are only 10 types of people, those who understand the binary system, and those who don't.
SeanStevens is offline
Old 15th May 2012, 12:29 pm   #3
JoshWard
JoshWard's Avatar
That is beautiful
Well done
JoshWard is offline
Old 15th May 2012, 4:57 pm   #4
telstar
Hi Josh. I have one of these great looking Philips radios. You are right though, they are difficult radios to work on.
Mike
telstar is offline
Old 15th May 2012, 4:59 pm   #5
telstar
Hi. Sorry I meant PJC58-Hythe.
Mike
telstar is offline
Old 15th May 2012, 5:14 pm   #6
Steve_P
Steve_P's Avatar
Why did they bother inventing Transistors?
Seriously though, that is one lovely set. Well done!
Cheers,
Steve P.
Steve_P is offline
Old 15th May 2012, 5:54 pm   #7
bobbyball
bobbyball's Avatar
Excellent set and effort!
I have several of these sets in the "roundtuit" pile awaiting attention... !
Robert
bobbyball is offline
Old 15th May 2012, 6:48 pm   #8
PJC58-Hythe
Thanks for all the comments..
The sound quality on this little set puts some of my big 'woodies' to shame, it is truly excellent.
Robert - good luck working on the ones you have! Nothing much phases me with regard to restoration but getting to anything that needs replacing on these sets is a real challenge, especially if it's under chassis and burried deep...
Peter
Old 15th May 2012, 8:55 pm   #9
bobbyball
bobbyball's Avatar
Cheers Peter!
I remember buying one of these (in brown) at the local "junk market" when I was a student in Preston in the 1980's It looked wonderful lit up although I never did cure the distortion on the output (presumably "that" capacitor and others) as much to my horror I managed to knock it off the mantlepiece in my room. Then it was only good for spares. Have a few more now to get going so as the lighter nights set in, who knows!!
Well done again anyway...
Robert
Old 17th May 2012, 9:45 am   #10
Andrew2
Andrew2's Avatar
This model always gives me a nice cosy feeling with its warm, golden glow. A styling masterpiece. Well done on preserving such a wonderful set.
Andy G1HBE.
Andrew2 is offline
