Old 14th Jun 2010, 11:59 am   #1
threeseven
threeseven's Avatar
Default Airband receiver, what to buy ?
Always had an interest in aviation and have often thought about buying an airband receiver, problem is I know nothing about them !
Any suggestions on what to buy including older sets ?
threeseven is offline
Old 14th Jun 2010, 1:45 pm   #2
RobinBirch
RobinBirch's Avatar
Default Re: Airband receiver, what to buy ?
Depends if you want something vintage or modern. You can get airband "handies" or scanners from ebay relatively cheaply.
Robin
RobinBirch is offline
Old 14th Jun 2010, 2:49 pm   #3
paulsherwin
paulsherwin's Avatar
Standard domestic radios that claim to have air band coverage usually just have an extended FM band. This isn't much use for serious listening, as most aircraft comms are actually VHF AM. It's possible to hear speech with a bit of deliberate mistuning but it's a struggle.
paulsherwin is offline
Old 14th Jun 2010, 3:01 pm   #4
threeseven
threeseven's Avatar
I'm open to suugestions, I like the look of the small portables but vintage stuff also appeals ! I do need advice on features, spec etc though.
Old 14th Jun 2010, 3:52 pm   #5
Station X
Station X's Avatar
The are generally plenty of cheap scanners on eBay. Some listeners stopped using them when the police went TETRA/Airwave. Just make sure it has an AM facility.
Be aware also that monitoring aircraft transmissions is technically illegal, but a blind eye is generally turned to it.
Graham. Forum Moderator
Station X is offline
Old 14th Jun 2010, 3:57 pm   #6
threeseven
threeseven's Avatar
What band do military aircraft use ?
Old 14th Jun 2010, 4:02 pm   #7
Station X
Station X's Avatar
225 to 400 MHz.
