Old 19th Apr 2019, 5:08 pm   #1
djsbriscoe
Default NAD 4300 tuner-Digital tuner with a Knob.
Bought myself an NAD 4300 FM/AM tuner. I am curious how the tlp801 photo interrupter (which works with the weighted flywheel tuning knob) works with the 4011 logic chips, TC9147AP synth chip and upc4558 chips to derive the tuning voltage for the front end in this tuner? There appears to be 2 phase comparator outputs on the synth chip but I'm not clear how the tuning voltage is arrived at. I'm guessing there is some kind of phase locked loop arrangement. Just not sure what the op amps do and how these components work together.
I'm just doing some research in case I need to fix it. Helps if I can understand how it all works first. I hope someone can help me learn something. Thanks.
David.
djsbriscoe is offline
Old 20th Apr 2019, 2:19 am   #2
Terry_VK5TM
Terry_VK5TM's Avatar
Default Re: NAD 4300 tuner-Digital tuner with a Knob.
The tuning voltage is derived from the 35v rail the 4558's are connected to.
Those 4558's are amplifying the output of the PLL/tuning IC which runs from the 5v rail.
That's the simple explanation
Terry VK5TM
https://www.vk5tm.com/
Terry_VK5TM is offline
Old 20th Apr 2019, 6:46 am   #3
Radio Wrangler
Radio Wrangler's Avatar
As you turn the tuning knob, segments alternately light and darken a light sensor. There are two light sensors, mounted in staggered positions, so by looking at the sequence from the pair of them, a small logic circuit can determine whether the knob is being turned clockwise or anticlockwise and it feeds pulses to either the 'up' or 'down' inputs of the PLL synthesiser chip. This counts up or down the frequency number stored in this chip. It goes to two places; the display to show you where you've tuned to, and it is translated to the appropriate division number for the PLL.
The PLL gets a sample from the tuner front-end's local oscillator, which it divides by that number. A phase detector compares the frequency out of the divider with a reference from a crystal oscillator. The phase detector steers the tuning voltage to the local oscillator to get its two inputs in step. So the LO is tuned to and held on the exact wanted frequency. The LO tuning voltage is shared with the tuner's RF stage tuned circuit, which are arranged to track the LO with the correct offset.
So turning the knob changes the frequency number displayed, and the phase detector makes whatever voltage is needed until it sees the LO is on the right frequency.
There are two of these systems, one for the FM front end, one for the AM.
Radio Wrangler is offline
