Old 5th Apr 2019, 11:08 am   #1
Frank.Keane
Default Brenell Mystery
Can anyone throw some light on this mystery Brenell? I can't find another one like it anywhere on Google. It doesn't appear to be factory spec. And I'm surprised to see the words Sunco Solid State on the front panel. Perhaps it was cobbled together?
ID:	180917   Click image for larger version
ID:	180918   Click image for larger version
ID:	180919   Click image for larger version
Frank.Keane is offline
Old 5th Apr 2019, 2:20 pm   #2
lesmw0sec
Default Re: Brenell Mystery
Never seen one of these before. My guess would be a minor manufacturer who has chosen to incorporate a Brenell deck.
lesmw0sec is offline
Old 5th Apr 2019, 2:22 pm   #3
Ted Kendall
Undoubtedly a one-off - Brenell decks were often used for home-brew machines, because of their high quality and versatility. The NAB version was the cheapest to offer this capacity by some margin ( if you ignore the Revox, which was an integrated design), and the provision for four heads made custom configuration easy.
Ted Kendall is offline
Old 5th Apr 2019, 3:10 pm   #4
wd40addict
wd40addict's Avatar
The magic eye doesn't look very solid state!
wd40addict is offline
Old 5th Apr 2019, 3:14 pm   #5
kalee20
I've only ever seen one piece of equipment with the Belling-Lee coax socket used to carry audio, and that's the Eddystone FM tuner!
kalee20 is offline
Old 5th Apr 2019, 3:34 pm   #6
barrymagrec
Belling-Lee coax sockets were used for audio signal purposes quite a bit way back - I think they were specified on most of the Mullard valve designs and the Williamson PX4 amp my uncle built also used one. Other than 1/4 inch jacks and those poxy little paxolin connectors there wasn`t a lot else readily available then - if you didn`t fancy American Phono / RCA types.
barrymagrec is offline
Old 5th Apr 2019, 5:55 pm   #7
Frank.Keane
Yes I did wonder about that Magic Eye myself. And the fact that the sockets seem to be the wrong vintage for a solid state preamp. The mystery deepens. And as for the name on the panel - can't find any reference whatsoever to Sunco audio equipment no matter how hard I search.
Old 6th Apr 2019, 2:21 pm   #8
rontech
It looks like a home construction using parts from various non-Brenell electronics added to a a somewhat modified Brenell deck. I think it may have done for amateur cinematography purposes to synchronise the sound with 8 or 16mm film.
I was in an amateur film society in the 60s and members made all sorts of strange systems to achieve that goal.
No problem nowadays of course.
Time flies like an arrow, fruit flies like a banana
rontech is offline
Old 7th Apr 2019, 7:59 am   #9
brenellic2000
Almost certainly a home-brew job cobbled up for a specific purpose.
Brenell decks were readily available to the DIY/amateur market but while Brenell bent over backwards to help such enthusiasts (many companies wouldn't), they did draw certain red-lines! The ambitious Cadey for example was tolerated by Brenell while allowing their semi-freelance chief engineer, Frank Underhill, to assist, but they didn't and wouldn't officially support the project.
Other oddities developed with specialist companies were more successful: auto-reverse decks, cassette replicators, ultra low-speed multi-channel decks etc...
Barry
Barry
brenellic2000 is offline
Old 9th Apr 2019, 12:04 am   #10
Michael Maurice
Michael Maurice's Avatar
Barry
Barry
What was the Cadey?
Forum Moderator
Michael Maurice is offline
Old 9th Apr 2019, 12:19 am   #11
Ted Kendall
An early attempt at a budget multitrack - the one I briefly possessed was 8 track, 1 inch, incomplete and unbelievably crude. The tape which came with it suggested that it had worked once, though I couldn't really credit it...
Old 12th Apr 2019, 11:00 am   #12
brenellic2000
The first Cadey was a Mk.510 deck modified with solenoid controls and 1" 8-track heads... so far so good. The cabinet and electronics were an amateur DIY'ers paradise stuffed full of cables best described as a bird's-nest... every time I open the case to think about tidying it up... I immediately close it!
They did work though, albeit on a shoe-string budget and were praised by some as a stepping stone to home studio. The next Cadey was more successful if only briefly. See my "Brenell - true to life performance history.
