Old 7th Sep 2019, 10:49 am   #1
ORAWA01
Default MFJ Dummyload faulty?
Hi All
I just received a used MFJ dummyload via the post. When I read the resistance from the dummyload, it reads 61 ohms instead of 50 ohms.
Surely this is faulty dummyload?
Is there way to adjust the resistance on the dummyload? Or should it be returned as faulty item?
Thanks
ORAWA01 is offline
Old 7th Sep 2019, 11:47 am   #2
Jon_G4MDC
Jon_G4MDC's Avatar
Default Re: MFJ Dummyload faulty?
Almost certainly impossible to adjust and might contain beryllium (should be marked). Dangerous to open if so.
61Ohms is not ideal but it is not terrible. VSWR is 1.22:1 if perfectly resistive.
Is the reading stable? Frequent failure with dummy loads is at the connection between pin and resistance element or resistance element to body. Check to see if it changes with slight pressure
on the centre pin or light tapping on a wooden block.
Maybe post the model number and someone might have another to compare readings?
Jon_G4MDC is offline
Old 7th Sep 2019, 12:01 pm   #3
ORAWA01
Thank you for your info and advice
Yes, the model is MFJ 260B. it looks very old the casing is all scuffed.
I opened it up, and checked all the connections and screws, and they seem OK. I tightened the screws further.
But even reading resistance across the element in the casing, it is 60 ohms.
All the connection is tightened up, so it seems the element which is giving 60 ohms true.
I hooked it up to TS-130SE, and fired up on 14Mhz with 100 W CW.
The SWR reading is 1.1 on the meter.
I have used another meter for the PWR output and SWR just to confirm, and they were the same 100W and 1.1:1 SWR.
I have another dummyload from ZETAGI DL50 and it reads 52 ohms. but it is rated for 50W max.
ORAWA01 is offline
Old 7th Sep 2019, 1:18 pm   #4
If it's a used one, someone may have overheated it.
Radio Wrangler is offline
Old 7th Sep 2019, 1:18 pm   #5
mickm3for
Hi i have mfj 989c this reads 57 ohms my home made one using eb** surplus telecoms resistor bolted to heat sink 4 inches square ex audio amp gives 50 ohms and 1 to 1 up to at least 430mhz its rated at 150w and 5ghz cheep i think £3.50 for 5 if memory serves me right just looked they have gon up ti 2.56 each https://www.ebay.co.uk/itm/RF-termin...YAAOSw0~pcEz~V
mickm3for is offline
Old 7th Sep 2019, 1:20 pm   #6
Terry_VK5TM
Terry_VK5TM's Avatar
It's possible it has been run either above it's rating or very close to it's rating for an extended duration.
This will cook the resistive element somewhat and as we all know too well, this can result in the resistance changing.
Bingo David
Terry VK5TM
https://www.vk5tm.com/
Terry_VK5TM is offline
Old 7th Sep 2019, 1:22 pm   #7
MrBungle
MrBungle's Avatar
If it’s MFJ it was probably broken when it came out of the factory like my ATU was. Not getting out was because there was a wire hanging off inside the tuner ffs.
MrBungle is offline
Old 7th Sep 2019, 1:49 pm   #8
It's said that MFJ denotes "Made From Junk", but I've never had any trouble with my MFJ-948 AMU.
Station X is offline
Old 7th Sep 2019, 2:03 pm   #9
If there's room inside you could always add a parallel 300R non inductive resistor or resistor combination rated for 20W or so. That'll get it back to 50R.
Herald1360 is offline
Old 7th Sep 2019, 2:15 pm   #10
ORAWA01
Wow, great advice. Thank you. I have a 220 ohm heat resistor somewhere in the draw. Maybe give a try with that?
ORAWA01 is offline
Old 7th Sep 2019, 2:19 pm   #11
ORAWA01
But yes, the MFJ used to be regarded as real poor product back in the early 1990s. Their ATUs used to cost a pittance, and no one respected them.
But they seem to have come a long way now. Some of their products such as antenna analysers 259 269s sell like hot cakes at high prices and their ATUs seem getting grabbed for good price too.
ORAWA01 is offline
Old 7th Sep 2019, 2:23 pm   #12
ORAWA01
I had an MFJ atu a few year ago, and it worked OK, but when you open the case and have a peek inside, you always feel the quality of the parts are a bit low grade stuff.
This 260B is from long time ago, and made with bare lowest grad parts, it feels.
I am wondering if I should return it for full refund for out of spec = 60 ohms is a bit too far off from the nominal spec on the paper for the product = 50 ohms.
And maybe have to go for a brand new one even at double the price. I think newer model 260C covers higher frequency albeit same power handing at 300W peak, and could be bought for about £50 brand new.
ORAWA01 is offline
Old 7th Sep 2019, 2:38 pm   #13
If you want a reasonable dummy load, you should be shopping for Bird, not another MFJ.
Old 7th Sep 2019, 2:56 pm   #14
MrBungle
MrBungle's Avatar
Bird stuff that works is expensive. I’m using a microset CF300 with a homebrew W7ZOI power meter and tap. The microset has flat VSWR to about 700MHz as it uses flanged RF resistors not those horrid carbon poles with a horrid tempco.
When I got into amateur radio I bought a diamond antenna “100W for ten seconds” load. It lasted two seconds at 100W then proceeded to emit smoke and now measures at 58 ohms. Thus you get what you pay for.
MrBungle is offline
Old 7th Sep 2019, 3:26 pm   #15
Jon_G4MDC
Jon_G4MDC's Avatar
Spec VSWR on that model is 1.3:1 so they are inside that.
Old 7th Sep 2019, 3:30 pm   #16
CambridgeWorks
CambridgeWorks's Avatar
Don't know exactly what that is, but needs to be non inductive. If it's an aluminium case wirewound type, it is no use.
Rob
Apprehension creeping like a tube train up your spine - Cymbaline. Film More soundtrack - Pink Floyd
CambridgeWorks is offline
Old 7th Sep 2019, 3:37 pm   #17
A dummy load is just that, a load, near enough for farm work as they say. A termination on the other hand should be quite accurate.
Old 7th Sep 2019, 4:26 pm   #18
Anything that works properly in this field is expensive.
Bird stuff is OK, but not precision. The measurement grade stuff from Weinschel, Narda, etc is even dearer.
I use attenuators rather than loads so I have an output for a spectrum analyser, or a precision power meter.
For something to check a transmitter is working, 60 Ohms will do, but it's disappointing. I'd suspect damage.
Old 7th Sep 2019, 6:36 pm   #19
ORAWA01
Rob
It is square pillar shaped ones, I used them to restore 1940s all valve radiogram once, and leftovers from the work. Like this one in the link.
https://www.digikey.co.uk/product-de...kaApcREALw_wcB
ORAWA01 is offline
Old 7th Sep 2019, 6:37 pm   #20
Sean Williams
Sean Williams's Avatar
Its not pretty, but look at this....
https://www.ebay.co.uk/itm/Ex-MOD-Bi...kAAOSwSlBY0qAM
I have something very similar here, ad it has worked flawlwssley for over 20 years....
Sean Williams is offline
