Old 11th Sep 2018, 6:50 am   #1
retailer
Default Will the real 6V4 please step forward
Going through and sorting a box of used valves I picked up what looked like an EZ81/6CA4, turning it over I saw it labeled 6V4 the European designation being EZ80, having just fished out a 6V4 a few minutes earlier I placed them together - clearly only one of them is a EZ80/6V4, I strongly suspect the larger one is an EZ81 it is not only taller, and has larger anodes but looks identical to the other EZ81's I have, was it labeled incorrectly ? it may have been but probably not, production costs of each must have been very similar so it was more likely that re-labeling was a cheaper option than stopping a production line and resetting it for what was essentially the same valve with higher specs.
It was very dirty with that greasy type of dirt that seems to be attracted to valves, strangely I managed to clean it with water and paper towel enough the get a photo with wiping off any of the label, I have other valves (and I'm sure others do as well) where the labels seem to magically disappear right before your very eyes, the very act of just removing them from the box is enough to almost wipe the complete label off.
retailer is offline
Old 11th Sep 2018, 10:22 am   #2
joebog1
Default Re: Will the real 6V4 please step forward
6CA4 in aussie speak is the superior valve. NEC made the best of them in my experience.
6V4 is a "radio" valve for moderate currents.
6CA4 is an "amplifier" valve for larger currents.
BOTH are small rectifiers. Akai Tape recorders ( valve types, or at least hybrid types) used 6CA4's in abundance.
BOTH run bl**dy hot if run at maximum ratings, but the 6CA4 didnt fail.
< ex service manager Akai )
Joe
joebog1 is offline
Old 11th Sep 2018, 9:20 pm   #3
G8HQP Dave
Rectifiers from different factories may have different anode shape/size yet still have the same rating. EZ80 and EZ81 have different heater current too, so they are not necessarily directly swappable.
G8HQP Dave is offline
Old 12th Sep 2018, 6:53 am   #4
retailer
Quite possibly my 6CA4 in 6V4 clothing was mistakenly labeled as a 6V4, I do believe though it is a 6CA4, I tried both valves in a HV power supply that I have and was able to separate the filament leads enough to get a clamp meter around one of them, even though the smallest range is 6 amps ac I was able to see that the larger valve drew almost twice the heater current of the smaller valve, this ties in with the info in my valve data manual - 1amp against 600mA. In a real life situation the extra 400mA of heater current would probably not unduly stress the transformer unless it was already a marginal design and right on the limit of it's ratings.
ID:	169149   Click image for larger version
ID:	169150   Click image for larger version
retailer is offline
Old 12th Sep 2018, 9:51 am   #5
turretslug
turretslug's Avatar
That bigger "6V4" is striking in that it looks to be similar in construction to "Rimlock" (B8a) valves, i.e. a separate hard glass base secured to the bulb with lower-melting-point frit- perhaps the glass equivalent of soldering, as opposed to the welding of the later miniatures! From what I've seen of EZ81s, they have a more complex anodes finning array, resulting in a six-sided "snowflake" arrangement viewed from above, as compared to the EZ80's cruciform arrangement. Perhaps this is an early/developmental 6V4/EZ80 with a more consumptive heater?
Anecdotally, I've noticed that it's not unusual to find the EZ81 fitted in things where an EZ80 is specified and adequate- perhaps they were plentiful or easily procured? I find it difficult to believe that they would have been cheaper. The EZ81's ratings are such that it was intruding on GZ34 territory- perhaps Mullard over-produced expecting that this miniature valve with its 6.3W consumption heater would be more successful at displacing the IO 9.5W type than was actually the case, with equipment manufacturers preferring to trust the longevity of the bigger envelope valve with its "traditional" separately fed 5V heater?
turretslug is offline
Old 12th Sep 2018, 2:41 pm   #6
G8HQP Dave
I seem to recall seeing an RFT EZ80 which looked internally more like an EZ81. Maybe just conservative engineering? Or is it that some Eastern bloc valves were more like substitutes for Western types rather than exact equivalents?
Old 15th Sep 2018, 3:00 pm   #7
G6Tanuki
G6Tanuki's Avatar
I can readily imagine that at some time in the production lifespan of things like the EZ80/81 it would have become more-economical to combine the production-lines and produce only the higher-performing valve for use in all applications rather than having two lines running. The 'fixed costs' [glassblowing, electrode-assembly, pumping] would have been the same for both valves, after all.
Better to have one production-line running at full capacity than two lines running at half-capacity.
G6Tanuki is offline
