10th Sep 2018, 1:07 pm | #1 |
Vintage Philips/Cossor tape recorder
Hello everyone. I am a new member, who after reading some posts about vintage tape recorders decided to get one.
It is a Cossor/ Philips Stellaphone 4track ST458/CR1604. The problem I have is it plays but does not rewind/fast forward and the tape counter does not work. Help needed please. I removed the cover and looking inside I can see a broken belt, the main drive wheel or is it a flywheel? has a belt around it. Can anyone describe where the other belts should go would the friction pads cause the rewind/fast forward problem? |
10th Sep 2018, 1:33 pm | #2 |
Re: vintage tape recorder
Hi and welcome . your FF and REW issues are solely related to belts . I would get a complete new set and replace the lot . The one on the capstan will be near to breaking anyway if the others have . Once you have those in place , then you can continue to diagnose any issues you have , this is how the belts go ....
There is a chap in italy on ebay I use for belts all the time . He`s great and all his belts are great too . search "SET BELTS EXTRA STRONG STELLA ST-458 REEL TO REEL NEW FACTORY FRESH ST458" and you will find him |
11th Sep 2018, 12:34 pm | #3 |
Re: Vintage Philips/Cossor tape recorder
Hi, wow thank you so much for your swift reply, your help is invaluable to me.Great to see a picture for reference. Is it fairly easy to replace the belts?.and oh nearly forgot any idea where I could obtain a microphone for this recorder.
12th Sep 2018, 12:36 pm | #4 |
This is a hybrid model and there may be sufficient stage gain for a magnetic microphone. A crystal type may overload it. You will need to find one with a DIN plug. I bet Maarten in Haarlem (Holland) will know!
Edward. |
12th Sep 2018, 4:03 pm | #5 |
Looking at it I would say the belts just slip on . Doesnt look like you have to remove anything . As for a microphone , I would start at ebay . Thats where I always go .
12th Sep 2018, 4:27 pm | #6 |
The photo in post #2 shows the top of the deck, but with the tape heads platform removed, so you would have to unscrew that first, in order to gain full access to the belts.
12th Sep 2018, 5:04 pm | #7 |
Thanks for that , I dont know the deck and I`m dumb as a brick so didnt notice it had no heads ..haha .
I can see it now laying over to the left ..lol |
12th Sep 2018, 7:04 pm | #8 |
Luckily these machines used belts made out of rubber rather than toffee!
13th Sep 2018, 8:19 am | #9 |
I presume you've seen this:
https://plus.google.com/photos/11744...55119520475761 Click on pictures for step-by-step instructions. |
13th Sep 2018, 12:30 pm | #10 |
Hi, thank you so much for all your replies, fantastic information given. This has given me the confidence to attempt repair.
