27th Jan 2021, 8:28 pm | #1 |
Leads For a Frequency Counter?
I recently bought a Thandar TF200 frequency counter, it should be with me soon.
I am wondering what cables members recommend I use with it as I'm not too sure myself. Input A is has an impedance 1Mohm and is in parallel with 25pF. Input B has an impedance of 50 ohms. Something that terminates in crocodile clips would be handy. I probably would need BNC to BNC leads and a splitter to connect multiple things together. All help appreciated! |
27th Jan 2021, 8:48 pm | #2 |
Re: Leads For a Frequency Counter?
Input A use a scope probe
Input B any 50 Ohm cable should be reasonable.... a bit of RG58 with a BNC on each end. make a BNC female to croc clips to go on the end if you must. You don't normally go probing around with 50 Ohm stuff. A 1k resistor in the end of another BNC femle can be useful David
27th Jan 2021, 9:08 pm | #3 |
Hi i second the scope probe as i use a x10 switched probe with mine great portable counter Mick
28th Jan 2021, 6:58 pm | #4 |
Thanks for the tips, they have been useful. The counter came today and I have had some time to play around.
An oscilloscope probe has been working well for input A. For input B I have used a BNC to phono adapter and a composite video lead. Things seem to be working well. |
