Old 17th Jan 2021, 12:21 pm   #1
Al (astral highway)
Al (astral highway)'s Avatar
Default Bonding acrylic to other materials?
Tricky. Two part epoxy doesn’t bond to it, it just peels off in a clean layer.
I’m also trying to bond it to fibre-glass braided sleeving.
Suggestions much appreciated.
Al
Old 17th Jan 2021, 12:32 pm   #2
stevehertz
stevehertz's Avatar
Default Re: Bonding acrylic to other materials?
I'm not sure what bond strength you're needing but I'd have thought that if the acrylic is strongly scuffed and scoured that epoxy would easily bond it to fibreglass. Obviously not so if it's highly polished.
stevehertz is offline
Old 17th Jan 2021, 1:09 pm   #3
Vintage_RC
Vintage_RC's Avatar
I would look at one of the Structural Acrylic Adhesives.
Alan G6PUB, BVWS
Vintage_RC is offline
Old 17th Jan 2021, 1:48 pm   #4
WME_bill
The usual adhesive for perspex acrylic is Tensol, made by Bostick.
It is a paste consistency of methylene chloride or chloroform with dissolved perspex. Works very well and I suspect the added perspex would serve to gum over your braided sleeving.
From Radiospares or on ebay. I have used it on damaged car light reflectors and number plates and bits of test equipment.
I used to use methylene chloride alone but it will soften almost any plastic surface and is not a nice solvent to handle - fumes. Used for dissolving off glues / resins / araldite for china repairs and restoring. Was the base of the original Nitromors paint remover which really worked, but now only obtainable by searching "industrially".
Tensol is said to be carcinogenic (as most chemicals seem to be now-a-days), so handle with gloves. And you will have to buy "industrially", not as a householder (in case you drink it).
You may find it worth while getting some isopropyl alcohol (propanol) for cleaning the surfaces as well. May be more difficult now as propanol is also used nowadays for killing Covid surfaces.
Try a search also for the PERSPEX HANDBOOK, I don't know who issued it, but contains useful information. Tensol 70 by Bostick.
wme_bill
WME_bill is offline
Old 17th Jan 2021, 4:40 pm   #5
Vintage_RC
Vintage_RC's Avatar
Tensol is a solvent adhesive containing chloroform for Perspex (acrylic), it won't bond acrylic to other materials. The OP is also trying to bond it to fibre-glass braided sleeving.
Alan G6PUB, BVWS
Old 17th Jan 2021, 4:50 pm   #6
emeritus
Small (57ml) bottles of methlyene chloride are sold for making for plastic model kits under the name "E.M.A. Plastic Weld". I have been getting my supplies from a stand at the local annual model railway exhibition, but I have seen it in shops that sell model railway stuff. I have also bought 57ml bottles of genuine methyl ethyl ketone from the same sources. I recall that there used to be a solvent for plastic kits called "Mek-pak" that stressed that it did not contain methyl ethyl ketone, but I haven't seen it for a while. I understand that the fumes from these solvents can be hazardous, especially for smokers: possibly sale in small quantities is permissible?
emeritus is offline
Old 17th Jan 2021, 5:36 pm   #7
G6Tanuki
G6Tanuki's Avatar
Have you considered treating this as a 2-stage process?
Initially, use an aggressive solvent [Acetone?] to soften the surface of the acrylic and then mechanically abrade it - 'stir it up a bit' with a sharp seeker/probe. Then you will have a 'key' for your later adhesive to bond-to.
Something similar was done to bond a single sheet of acrylic [about 2-foot-square] to the front of a control-panel for use in sewage-farms (ugh!). the acrylic was masked and the exposed parts then etched with the solvent before bonding with a cyanoacrylate-type adhesive. Big problem was getting the bubbles out from the bond.
G6Tanuki is online now
Old 18th Jan 2021, 10:01 am   #8
Al (astral highway)
Originally Posted by stevehertz View Post
... I’d have thought that if the acrylic is strongly scuffed and scoured that epoxy would easily bond it to fibreglass. Obviously not so if it's highly polished.
Good idea, Steve. I’ll try that, abrading the acrylic surface somewhat first.
Also thanks to everyone else.
Tensol is a horrible compound but it definitely does what it should- bond acrylic to acrylic. It doesn’t bond to other materials.
Al
Old 18th Jan 2021, 11:44 am   #9
The Philpott
The Philpott's Avatar
Al, If you have a test piece available hot-melt glue stick could be tried. The bond i made between PA6 (Nylon) and an unknown plastic (!) still holds firm.
Dave
The Philpott is offline
Old 18th Jan 2021, 11:50 am   #10
Al (astral highway)
Originally Posted by The Philpott View Post
...hot-melt glue stick could be tried. The bond i made between PA6 (Nylon) and an unknown plastic (!) still holds firm.
Hi Dave, thanks for the tip!
I like this idea. I'm sure it will be plenty strong enough, I'll try it out.
Al
