2nd Dec 2006, 9:16 pm | #1 |
Curious old military(?) receiver
I'm looking for information on this set. I aquired this set years ago, salvaged from a skip somewhere, speaker missing and a broken valve. It has a 'vibrator' unit on a small separate chassis sharing the box. It has the War Department logo, W ^ D, marked on the top by the handle but i am dubious that a wooden boxed radio for only medium wave has any military use at all. It looks original and at one stage had a rear panel, as shown by the rear panel securing attachments, but i never saw it. I will try to take better pictures if it will help. John |
2nd Dec 2006, 9:38 pm | #2 |
Re: Curious old military(?) reciever
Could it be good quality home construction? The PSU looks as though it has been 'borrowed' from something more glamorous.
2nd Dec 2006, 9:55 pm | #3 |
To me, it looks like the main chassis is out of a factory-manufactured radio, fitted into a home-made case. The vibrator unit, as an ex-equipment add-on, fitted to run the whole affair from LV dc. Could this be a modification / re-work for use in a caravan, boat or something similar? That type of carrying-handle strongly suggests such an application - i.e. an early "portable" radio.
I do not believe that it has any military "connections" whatsoever. The "W^D" marking just happened to be already on the case - which may well have originally housed a piece of military gear - when it was re-worked to accomodate the chassis & vibrator. Just my contrib. Al / G8DLH |
2nd Dec 2006, 9:59 pm | #4 |
I reckon that is a wartime "NAAFI" set, I believe they were powered from a 12 volt battery. I think one appeared on ebay a while ago .
Regards Mick. |
2nd Dec 2006, 10:48 pm | #5 |
It's a "Receiver Broadcast Type C No.4".
Portable Army Broadcast receiver. 4 valves. 6V DC Operation. 185 - 550 metres. 465 KHz IF Manufactured by Hale Electrical Company Limited (HECL). Source "Wireless For The Warrior Volume 3 Reception Sets".
2nd Dec 2006, 11:16 pm | #6 |
Aha - they were the manufacturers of Etronic domestic receivers. Wooden ones turn up quite often, mostly basic 4+1 valve sets using octals, and they also made the "Midgetronic" bakelite set that's rather odd and moderately sought-after: if memory serves, it was the first domestic radio to use a printed circuit board. According to Dave Hazell's serial listing of manufacturers in the BVWS Bulletin, Hale were probably wound up in 1952. There might well be a strong resemblance betweeen the chassis of your set and the early post-war Etronic designs.
Paul |
3rd Dec 2006, 12:55 am | #7 | |
I don't know whether any domestic receivers had vibrator PSUs, but that will have to be the subject of another thread.
3rd Dec 2006, 5:20 am | #8 |
I too wondered if it was not a military radio, but someone had maybe used WD parts, but the case did not look as though it had ever been used for anything else. However it looks as though it has been recognised. As a NAFFI radio, i suppose its function was not primarily military, in the active sense, but more similar to a domestic sense. That would also explain the vibrator unit, as it may have been operated without electric mains. I had wondered if it might have been used at an army establishment, but if so, i couldn't see the need for the vibrator unit. I suppose that inspecting the valve heater wiring would tell me if its meant for six or twelve volt working. G4ILN, Thank you very much for identifying this set for me, however i still can't find anything about it on the net. I would like to fit an appropriate speaker into it which would look right, so if theres any chance of a picture, could you post one ? This picture of the dial shows exactly the same wording as you posted. Cheers, John |
3rd Dec 2006, 1:19 pm | #9 |
The power supply is similar top this one:
http://www.g1jbg.co.uk/mil1.htm Though it looks like the 0Z4 has been replaced with either a synchronous vibrator, or a selenium rectifier. Jim. |
3rd Dec 2006, 1:34 pm | #10 |
The speaker was simply a normal round type of diameter to suit the grille. I have a rather crude picture which I'll scan later and post here.
Interesting that the set seems to use a variant of the AR88 PSU. Thanks Jim.
3rd Dec 2006, 10:43 pm | #11 |
Here are a copuple of scans from "Wireless For The Warrior Vol 3" :-
http://home.wxs.nl/~meuls003/home.html The view of the chassis is of a Receiver Broadcast B No. 3 which incorporated a tropical band in addition to MW. It gives a good idea of the speaker type.
5th Dec 2006, 5:22 am | #12 |
Thanks very much for the pictures. I still have not found any mention of this set on the net anywhere. The speaker looks ordinary enough in that pic, i will wait until i find one that fits the existing screw holes. There is no doubt that it is the same wireless, although there may have been different versions of it. The set in the picture looks like it has a lid. Mine has no lid, nor any indication that it ever had a lid, the sides are not protruding a little as they are in that picture and there are no signs of any screw-holes or missing hinges. Which is a shame, it would be nice with a lid. But i won't change it. The knobs look very much like knobs i've seen before from that period, so i should be able to find suitable ones alright. I can't make out that piece above the dial. On mine there is a hole. Like a hole for a control shaft, but theres nothing inside near it. Maybe its just a name-plate. If it was used by the NAFFI then i suppose it would have been used in a tent, or even in the open where there was no mains supply. Which i suppose would explain the vibrator unit. I still think its odd that a radio like this has no facility to use the mains, only a battery supply. Regards, John |
5th Dec 2006, 7:32 pm | #13 | |
There were many different types of Welfare Receivers used in WW2 and they had various PSU arrangements, including some mains powered sets. Many vehicles of this era had 6 volt electrics, which probably explains why 6 volts was chosen for this set. If you get in touch with Louis Meulstee via his website he may be able to tell you a bit more about the set or maybe knows someone who knows more about it.
11th Sep 2007, 9:15 pm | #14 |
I agree it is as stated a Receiver Broadcast Type C No.4. I've just picked a brand new one up dated 1940, sold in a army surplus shop in 1968 and then after accidently being plugged into 12 volts instead of 6 reboxed and left until I brought it
11th Sep 2007, 10:10 pm | #15 |
Congratulations on your purchase.
So. All the valve filaments burned out and possibly a burned out vibrator then? I wonder if double the HT voltage damaged any capacitors? Or maybe you'll be luck and find nothing more than a blown fuse?
11th Sep 2007, 11:10 pm | #16 |
HECL - Hale Electrical Company Limited - I restored one of these a long time ago for Bletchley Park - think it has gone to Duxford now....
Not a bad radio, hope the powersupply has survived ok.
11th Sep 2007, 11:19 pm | #17 |
A quick check and I've been lucky all the heaters are fine, I've got a heavy duty transformer to make a 6 volt power pack so I'll let you know how things go
