Old 20th Jul 2018, 11:35 am   #1
sortedradio
sortedradio's Avatar
Default Garrard turntable identification help needed
I recently purchased this Plus O Gram unit with a Garrard turntable as pictured.
It is 78rpm only,with an ac motor marked for 100-130 & 200-250V 16 Watt. I haven't powered it up yet or done any testing. One obvious issue is that the arm doesn't return to the rest. I think it may have been forced towards the centre of the turntabe at some time. It looks fairly simple to loosen the clamp holding the arm and re adjust it. The cartridge is marked 2000 ohm and is also untested.
Can anyone identify the turntable or provide any information on this deck? Thank you.
ID:	166291   Click image for larger version
ID:	166292   Click image for larger version
ID:	166293   Click image for larger version
ID:	166294   Click image for larger version
Martin
BVWS member
GQRP Club
sortedradio is offline
Old 20th Jul 2018, 12:55 pm   #2
Heatercathodeshort
Heatercathodeshort's Avatar
Default Re: Garrard turntable identification help needed
Looks like a Type E unit. Dates from around 1946. John.
Heatercathodeshort is offline
Old 20th Jul 2018, 1:11 pm   #3
sortedradio
Thanks John,
Removing the platter has answered my own question. It's a model S. I am guessing its probably from the 1940s. I have now tested the motor, which is fine. It could do with a clean and some lubrication. Suprisingly the rubber tyre on the idler seems good.
Martin
BVWS member
GQRP Club
Old 20th Jul 2018, 4:56 pm   #4
RojDW48
RojDW48's Avatar
I haltingly restored one of these with lots of help from members some time ago - so this thread might help - https://www.vintage-radio.net/forum/...d.php?t=121284
'....don't go mistaking Paradise for that home across the road!' (Bob Dylan)
RojDW48 is offline
Old 20th Jul 2018, 5:54 pm   #5
sortedradio
Thank you RojDW48,
That's very helpfull, I think I will have to carry out the same procedure on the head. Looks like fun!
Martin
BVWS member
GQRP Club
Old 20th Jul 2018, 7:56 pm   #6
rontech
My father had a very similar unit as a second record player in the late 1940's.
To start the turntable , the arm needed to be moved well over to the left which turned on a toggle switch.
Moving the arm over to near the centre spindle either manually or under the action of the run out grooves re set the toggle to the off position.
The pick up head worked fine into the gram inputs of the late 1930's Marconiphone
radio we had.
rontech is offline
Old 5th Sep 2018, 12:28 pm   #7
rontech
Just noticed an error in line 2 of the above.
It should read ----------------- well over to the right which turned on a toggle switch!!
rontech is offline
