12th Jul 2018, 8:12 pm | #1 |
BSR X4H. Is it stereo compatible?
Hello.
Just bought an old Portadyne record player for the Monarch UA15 deck as I needed the arm mount because the one I have is broken. It came with an X4H cartridge which still works. Is it stereo compatible like the X5H? Many thanks, John. |
12th Jul 2018, 9:02 pm | #2 |
Re: Bsr x4h. Is it stereo compatible?
Hi John
I believe your X4H cartridge is indeed stereo compatible. The first BSR compatible cartridges were the X3 range. Regards David |
12th Jul 2018, 9:19 pm | #3 |
That's really interesting. For all my years in association with BSR in manufacturing and re-selling, I never knew there was ever existed a BSR X4 series? There was a very early TC4.
Also, I believe the X5 series preceeded both the BSR X3 and X1 series, but I stand to be corrected.
Edward. |
12th Jul 2018, 9:25 pm | #4 |
Hello Dave,
Thanks for your prompt reply. I will use it and keep the X5H as a spare. The X4H is plenty loud enough. Many thanks. John. |
13th Jul 2018, 8:32 am | #5 |
Re: BSR X4H. Is it stereo compatible?
I agree with Edward, but I’m not an expert and I keep learning every day.
Cheers John |
13th Jul 2018, 5:21 pm | #6 |
Hello all,
I have a photo to attach but am unsure how to proceed. I have created an album which is the picture of aforementioned x4h. Any help would be much appreciated. John. |
13th Jul 2018, 6:21 pm | #7 |
One extra for Ben to add to his list!
Cheers John |
14th Jul 2018, 5:07 pm | #8 |
Hello all,
How do I attach a picture to thread? Many thanks. John. |
14th Jul 2018, 8:18 pm | #9 |
Frank |
14th Jul 2018, 9:27 pm | #10 |
Looking forward to seeing a picture as I have never seen an X4 cart.
Regards, Ben. |
14th Jul 2018, 10:31 pm | #11 |
Hello Frank,Ben,Edward.
Here are the pics. Sorry for the delay. John. Last edited by john.north; 14th Jul 2018 at 10:33 pm. Reason: Wrong info |
14th Jul 2018, 11:08 pm | #12 |
I also didn't know that a X4H was ever made. Have replaced many X5H over the years and I have seen a few X3H, mainly in late 1960s record players. You never stop learning in this game.
Alan. |
14th Jul 2018, 11:31 pm | #13 |
Hello all,
The x4h is smaller than the x5h and the mounting clip is white plastic instead of steel. I am using it as a replacement for a TC8h in a Dansette Senator. The x4h came out of a Portadyne r/player radio but would probably have been fitted with a TC type. It would be interesting to know the output of the x4. I think the TC8h is 850mV. John. |
15th Jul 2018, 1:22 pm | #14 |
Regarding my unfamiliarity with this "newly discovered" BSR X4H - what I find unusual is the self-adhesive sliver label attached to the cartridge body. All BSR cartridges of this period, before and after have the type designation engraved and colour filled or moulded into the cartridge body. I wonder if this is a clone?
Edward. |
15th Jul 2018, 5:45 pm | #15 |
Hello all,
Edward you could be right, that is why I wondered about the white plastic mounting clip. The two X5H's that I’ve got have a steel clip or you can use the screw hole on top. The X4 clip is the same mounting as the X5. I will send some more pictures later. John. |
15th Jul 2018, 6:06 pm | #16 |
15th Jul 2018, 6:30 pm | #17 |
I agree with Edward, when I saw the label it didn’t ring true!
Cheers John |
15th Jul 2018, 7:23 pm | #18 |
Hello all,
Here are more pics of x4 and x5 with mounting clips. John. |
15th Jul 2018, 8:13 pm | #19 |
I still am inclined to suss the provenance of this "X4H". Just see the way that BSR designate their cartridges as per the legitimate X5H on the right. I just don't think this was made by BSR.
Edward. |
15th Jul 2018, 8:32 pm | #20 |
The cart body looks like a C1 or similar from below. This cart may be a rebadged USA type, Astatic or something of the same era.
Regards, Ben. |
