Old 30th Jun 2018, 6:37 pm   #1
theredhouseinn
theredhouseinn's Avatar
Default Mullard Valve Tester 7600/3
I am refurbishing a Mullard automatic valve tester model 7600/3. This is the version withe 2 EF91's and 2 EY51's.
I had to remove and refit the T1 mains tx and I am left with tag 3, in the group next to the 4 large welwyn resistors, with no connection. I do not have any spare wires floating around so I think that tag 3 is possibly linked to another tag and the link became detached during the removal and refitting of the tx.
the tx is behind the left hand panel of the tester.
If anyone can help me with this one please reply
Regards.
John.
theredhouseinn is offline
Old 17th Jul 2018, 8:48 pm   #2
Ed_Dinning
Default Re: Mullard Valve Tester 7600/3
Hi John, I believe there are several threads on this tester in the test equipment section, possibly with schematics, but not necessarily wiring layouts.
Ed
Ed_Dinning is offline
Old 17th Jul 2018, 9:19 pm   #3
PJL
The circuit diagram is not much help and as I remember the wiring is pretty packed around the transformer. If you have removed it, how confident are you that all the other connections have been replaced correctly.
Can you post a picture and mark up the position of tag 3.
PJL is offline
Old 17th Jul 2018, 10:00 pm   #4
buggies
buggies's Avatar
Not sure if this picture will help - extracted from this thread in the forum:-
https://www.vintage-radio.net/forum/...55&postcount=4
George
buggies is offline
Old 18th Jul 2018, 9:37 am   #5
theredhouseinn
Thank Ed.
Thanks for the replys guys.
The thumbnail from George solved my problem.
As I was moving the tx about the solid core wires were breaking off the tags.
I labelled all the wires as I was unsoldering them. I got tags 3 & 4 wrong as they dropped off before I could label them.
Tip. If you have to remove the tx, label the wires before dismounting it. Or take a close up pic.
After 60 years you would think I would learn!!!!
John.
Old 19th Jul 2018, 9:14 pm   #6
buggies
buggies's Avatar
Good luck with the rest of it...
George
buggies is offline
