Old 27th Feb 2021, 1:52 pm   #201
Helder Crespo
Helder Crespo's Avatar
Default Re: My first telly TV22
Originally Posted by Travellingwave View Post
I have gathered the bits for my LOPT rewind...
Hi
This is impressive! Looking forward to your video and results.
Helder
Helder Crespo is online now
Old 27th Feb 2021, 6:13 pm   #202
Travellingwave
Your use of an Arduino for the wire feed guide could mean it also has the potential to work as a wave winder as well.
I was wondering about that - in principle I see no reason why not - its just an electronic cam function - in my day job I do a lot with multi axis servo systems and robots and this is a standard function - should be possible to implement with steppers - probably using Gcode would be the easiest way.
I read somewhere that the wire is impossible to get hold of if you were to try to rewind the overwind for example - but what is special about it?
Travellingwave is offline
Old 28th Feb 2021, 8:11 pm   #203
Travellingwave
So I cobbled together my coil unwinding machine and dissected the LOPT windings.
I am in the process of uploading a video to youtube and will share it once that is done.
As far as I could tell there may have been two places where the primary and secondary were connected - one at the end of the last layer of the primary , the paper seems very crumbly at the ends of the winding, but also there was another fault somewhere in the middle of the last layer.
Overall a straightforward operation - lets see how putting it all back on again works out!!.
Old 28th Feb 2021, 8:53 pm   #204
Travellingwave
Here is link to video. Will try to get rewind done some time next week work permitting.
https://www.youtube.com/watch?v=SKLh...ature=youtu.be
Old 28th Feb 2021, 9:40 pm   #205
Helder Crespo
Thanks for the video!
What was your turn count in the end?
Helder
Old 28th Feb 2021, 9:47 pm   #206
Travellingwave
Pretty much as posted by Andy(Beery) give or take a turn.
Old 28th Feb 2021, 10:07 pm   #207
Travellingwave
Here is the final score
The paper used between layers measured at 0.11mm thick , so the magneto tape I have is thinner than this
ID:	227934   Click image for larger version
Old 28th Feb 2021, 10:13 pm   #208
Helder Crespo
Thanks. Your turn count is really spot on. As for the paper thickness, I think your measurement is a bit off. A standard A4 sheet is 0.1 mm thick (hence 500 sheets make up a 5 cm tall pack). The paper in the lopt is surely thinner than an A4 sheet.
Helder
Old 28th Feb 2021, 11:12 pm   #209
beery
beery's Avatar
I agree,
it must be thinner than that.
When measuring such small things as paper insulation or even wire diameter, I always use a micrometer, which is much more accurate than a caliper.
Good to know my turns count wasn't far off.
Andy
beery is offline
Old 1st Mar 2021, 3:34 pm   #210
Helder Crespo
Based on the post-mortem, where do you reckon the short took place? From your video it seems to have been roughly in the middle of the central portion of the coils. Quick question: I known it can be very hard to determine, but were you able to check if the paper was / had been impregnated with white spirit in that area? As for the rusty ends of the laminations, my varnished lopt was in a very similar condition to yours. I think that if the problem is only at the top/bottom, this should not make a huge difference in performance (the magnetic circuit is open/lossy anyway), apart from potential vibrations that can be minimised by tightening and restraining the ends. The rust layer is actually an insulator, provided it is dry (or immersed in white spirit) and then varnished.
I never fully disassembled my lopt. Prior to varnishing, I simply squeezed the laminations together and machined a small restraining piece to keep them together (see photo below).
Helder
Old 1st Mar 2021, 7:16 pm   #211
Travellingwave
Hi Helder
I think there may have been two faults , one at the end of the final layer and one in the center of the final layer.
My impression is that the white spirit hadn’t reached into the center of the windings. The winding when originally done seems to have had molten wax brushed on ( I’m guessing) so my impression is of an homogenous mixture of wire/paper/wax and no smell of white spirit.
I’m pretty sure that white spirit/varnish would help with reinforcing the insulation at the ends of the windings which is probably where most faults would occur.
As for the thickness , I am probably measuring wax and paper , the paper/wax has the impression of the wire embossed into it , so the actual paper may well be thinner
Old 1st Mar 2021, 9:29 pm   #212
Ed_Dinning
Hi Folks, a piece of heavy duty heatshrink tube works wonders in keeping the lams together
Ed
Ed_Dinning is offline
Old 1st Mar 2021, 10:06 pm   #213
Helder Crespo
Hi Helder
Hi
Thanks. Wax & paper are definitely not a good combination (think capacitors). Based on your results, I think it is unlikely that any varnish has made it to the central portion of the windings in my lopt, so I agree with you that the protection is mostly at the ends. On the other hand, the white spirit and varnish (given enough immersion time) should be able to infiltrate into the very same areas where humidity (and air) tend to go to, and hence where reinforcement is more important and necessary. I don't know how long my varnished lopt will last, but Argus25's TV22 lopt was "turped & varnished" many years ago (10+?) and is still going strong, whereas my first lopt (left original and untreated) lasted for a few hours prior to developing the dreaded short.
Helder
Old 1st Mar 2021, 10:14 pm   #214
Helder Crespo
Ed
Thanks Ed. I did consider that option, but given that I didn't disassemble my lopt, the accessible area was rather small, hence the machined retaining ring.
Helder
Old 2nd Mar 2021, 12:21 pm   #215
Travellingwave
I guess in due course I will discover if dismantling this thing was a good idea or not. But it’s an interesting learning curve and if I get stuck hopefully I can send it to Ed to be properly done!
Old 2nd Mar 2021, 12:31 pm   #216
Travellingwave
I suppose a halfway house would be to remove the inner windings and immerse those in a very much thinned down varnish , even better under vacuum. That way you would not make it very difficult to remove again later if a fault did occur.
The transformer varnish I used ( from RS components) seems to dry to an almost caramel consistency to is quite easy to crumble off if needed. Not sure standard varnish would be as easy to remove for reworking if needed.
Old 2nd Mar 2021, 4:50 pm   #217
Helder Crespo
Ok. Please remember that you'll probably have to adjust the 470pF tuning cap (increase or decrease the capacity) in order to get the lopt resonating near its maximum efficiency. Once you install it, the mismatch will be noticeable in the raster width. Too narrow, you need to increase the capacity; too wide, decrease it. With the rewound lopt in my first TV22 I had to add 200pF. I used a 1000V-rated dipped silver mica. Just don't use standard 630V poly caps; a 1000V one will probably survive, but will introduce more losses than the silver mica cap.
Helder
Old 2nd Mar 2021, 5:43 pm   #218
Freya
Freya's Avatar
Peak voltage across the capacitor is 830 volts
Stephen
Freya is offline
Old 2nd Mar 2021, 6:56 pm   #219
Travellingwave
Ok thanks for the info
Lams are in vinegar deejaying
SHMBO not impressed at consumption of good wine vinegar
Old 2nd Mar 2021, 6:56 pm   #220
Travellingwave
Derusting i mean
