Old 18th Feb 2018, 2:18 am   #1
Alf
Alf's Avatar
Default 12.6v heater version of 6V6/6BW6
For some time I've been wondering if there was a 12.6v version of the ubiquitous 6BW6/9BW6/6V6 valve, and it seems that there is, the 12CM6 (also 6CM6 6.3v)
Alf is offline
Old 18th Feb 2018, 3:30 am   #2
usradcoll1
Default Re: 12.6v heater version of 6V6/6BW6
The 12V6GT was designed for the new 12V GM cars starting in the 1953 model year. They were used all the way to 1958 in some GM radios, both single ended and push-pull.
Around the mid to later 50's, all car radio manufacturers were starting to switch to Space-charged valves, 12V anodes and screens, thus eliminating the HT power source and using a high power type transistor.
The only counterpart valve of the 6CM6 that I know of is the 12AB5, which is the 12V version of the 6CM6. Motorola used them in their first 12V car radios.
usradcoll1 is offline
Old 18th Feb 2018, 3:31 am   #3
Synchrodyne
There were also the 12V6GT and 12AQ5, introduced 1952-53 for use in 12-volt car radios. Many 12-volt applications were already covered, as most of the 150 mA AC-DC series-string small-signal valves happened to have 12.6-volt heaters. But there were some gaps that needed to be infilled with new 12.6-volt issues as the American car industry swung from 6-volt to 12-volt electrical systems.
Cheers,
Last edited by Synchrodyne; 18th Feb 2018 at 3:32 am. Reason: Crossed with USRadColl1's post.
Synchrodyne is offline
Old 18th Feb 2018, 10:46 am   #4
John M0GLN
John M0GLN's Avatar
Obviously not the same as the 6V6 and 12V6 mentioned in the previous posts, but it had me puzzled for a while when looking at the schematic of a RCA Victor AA5 set and the output was a 50L6, what on earth made them use a 50V version of a 6L6 in a such a small wireless, a bit of delving into my valve data book revealed that the 25, 35 and 50L6 were not the same as the 6L6 with different heater voltages.
John
John M0GLN is offline
Old 18th Feb 2018, 11:35 am   #5
turretslug
turretslug's Avatar
I think that the US setmakers generally had the quandary that HT derived directly from their mains made it difficult to get respectable output power (or good advertising copy, anyway....) with valves that were comparable with the 6V6, so the xxL6 variants needed to be called on with their greater heating power and emissive area to drive a greater current swing through the output transformer primary. This trend is also quite noticeable with US shipboard communications receivers that had to cater for 110VDC supplies where something like a 25L6 might be fitted, yet only yielding 1-1.5W audio power.
turretslug is offline
Old 18th Feb 2018, 12:08 pm   #6
vidjoman
There was a 25V6 as well. I used it in equipment built as an apprentice back in 1957.
Don’t forget the valves we are talking about have American origins and the heaters would have been created at different voltages/currents to suit series heater chains operated directly from 110 volts.
vidjoman is offline
Old 18th Feb 2018, 3:00 pm   #7
paulsherwin
paulsherwin's Avatar
Yes, the 50L6 was popular in American sets because it allowed the construction of AA5s without a dropper resistor. There were fewer benefits for 220/240V sets.
paulsherwin is offline
Old 18th Feb 2018, 7:28 pm   #8
G8HQP Dave
I believe I have one or two 19BW6, the 150mA version.
G8HQP Dave is offline
Old 18th Feb 2018, 7:42 pm   #9
G6Tanuki
G6Tanuki's Avatar
What about the 12A6?
http://www.r-type.org/exhib/aaa0599.htm
Used extensively in US WWII gear such as the 'TCS8/12'-series of receivers [which as well as using a 12A6 as the output-valve use another one as the receiver local-oscillator!]
G6Tanuki is offline
