Old 18th Feb 2018, 1:20 am   #21
julie_m
Default Re: Why did manufacturers use 5 volt heater rectifiers?
Couldn't you just use an EM84 in a 300mA TV heater chain, with a shunt resistor to make up the current difference?
julie_m is offline
Old 18th Feb 2018, 3:16 pm   #22
Herald1360
Herald1360's Avatar
WOT?!
Put an extra resistor in a telly?
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is online now
Old 18th Feb 2018, 11:19 pm   #23
julie_m
They would make fewer of the PM84, though, seeing as not all TVs would be fitted with one; so you'd expect them to be sold more expensively than an EM84 (found in almost every tape recorder), and probably by more than the cost of a resistor.
julie_m is offline
Old 18th Feb 2018, 11:29 pm   #24
turretslug
turretslug's Avatar
Perhaps there was also a worry that, on switch on, the 0.2A heater of the E-eye would be proportionately harder hit as its shunt would be ohmic? Also, a bit more assemblage involved with a resistor, who knows what calculations go on with OEM quantities, T + M, favoured valve-maker deals? It might all seem arcane- but so does the 35Y4/35Z5 thing with a bulb across part of the heater to save on resistors, this time with the opposing attraction that the rectifier goes phut a little quicker when the inevitably short-lived bulb fails....
turretslug is offline
