8th Feb 2018, 1:02 pm | #1 |
ILP 6C205 Toroidal Transformer
I got a couple of ILP toroidal transformers this morning (well, they were very cheap). The only indentification on them is the type number 6C205.
There's a black and a white wire coming out one side and some coloured wires coming out the other. I assume the first lot are the primary, and that it's wound for 230V mains. But before I power them up with a lamp limiter and measure the secondary voltages, does anyone have any information (connections, voltages, VA rating, etc) on them? |
8th Feb 2018, 1:09 pm | #2 |
Re: ILP 6C205 Toroidal Transformer
Last edited by Station X; 8th Feb 2018 at 1:10 pm. Reason: No need to disguise a company email address. |
8th Feb 2018, 1:10 pm | #3 |
I'd be a little wary of the Black and White wires - US standard for live and neutral.
So they may be 120v primary. Vic Edit; This site http://www.transelectro.com/index.as...oidal/standard has data on physical size which may guide you on approximate VA rating. Last edited by Vicboduk; 8th Feb 2018 at 1:24 pm. |
8th Feb 2018, 11:51 pm | #4 |
I agree with Vicboduk!! Also when I make, or have made for me, toroidal transformers I sometimes specify, for instance, a 300 watt core and overwind it to only run at 1 Tesla, so the end product is rated at 180 VA. In other words, it changes the flux density.
I do this specifically with toroids for test equipment and pre amplifiers to reduce external fields, although I always use an external flux band to this end. Regardless, ILP make very nice transformers. Best regards. Joe. |
9th Apr 2018, 7:46 pm | #5 |
I've done a few tests on these today, and I am pretty sure they are not for mains at any common voltage.
There are 6 separate windings. One to the pair on its own, the other 5 to 5 pairs of wires in the 10 wire bundle. All windings have a DC resistance of less than 1 ohm. Needless to say applying mains to the pair on its own with a lamp limiter results in a brightly glowing lamp. I do wonder what these transformers are for. Not high frequency, so not an SMPSU part (or RF, or anything like that). Not mains. Audio output? |
9th Apr 2018, 8:12 pm | #6 |
Quad 99 FM and CD use a bussed power system from the 99 pre so use mains type transformers with 30 - 0 - 30 ish primaries.
9th Apr 2018, 10:08 pm | #7 |
Perhaps for a push-pull LV inverter/converter, with some of the windings being for feedback purposes? Various conceivable possibilities of a requirement to go from 12V to 24, 48 etc. or vice-versa perhaps, I'm sure at one point I had one or two Avbel-Lindberg toroids for 24 to 36VDC converters.
10th Apr 2018, 12:00 am | #8 |
Would it not be two tapped 90 to 120 or so volt windings with a single secondary.
Try them in series on the lamp limiter and see what happens. |
10th Apr 2018, 12:22 am | #9 |
Refugee has a very good idea. "MOST" toroid transformers made recently follow the convention of
Brown - Orange 120 volts ( brown = start, orange = finish ) Black - White 120 volts (black = start, white = finish) There may possibly be a green, or green yellow as well which wont connect to any other wires. It will be the electrostatic screen between primary and secondary. DC winding resistances on toroids can also be confusing!! A very high flux transformer may only have a winding resistance of an ohm or two, yet will supply 100 watts or more, whereas more conventional EI transformers we "expect" to see something in the vicinity of 8 - 15 ohms. All the above may not have any relevance to your transformers however. ALSO, I am assuming that these are mains transformers. Joe |
10th Apr 2018, 5:05 am | #10 |
The 10 wire side of this transformer has the wires of the obvious 10 colours and they are paired as follows :
black-brown red-orange yellow-green blue-violet grey-white. 5 separate windings, no taps. And then the black-white winding on the other side. No taps on any winding. Given that the lamp limiter lit very brightly on the black-white winding, I am sure that was not designed to go across the mains. I may try feeding a few volts AC across that winding and see what I measure on the other wires. |
10th Apr 2018, 7:05 am | #11 |
It could be something very peculiar.
Mainstream toroids are somewhat formulaic. The manufacturer has a range of core sizes and each one sets the VA rating. Knowing the VA and knowing the standard mains voltages of their market means they can have a standard primary design for each core size. They can put the primaries on and then the heavy insulation layer and keep them in stock waiting for an order saying what secondary is needed. This breaches the principle of winding the highest current winding on the smallest diameter, but it's great for production logistics. It isn't nice burying solder joints inside a transformer, so it's easier to bring either a loop of the wire out and back in again, with a single sleeve slipped over it, or else treat everything as separate windings. So, if it's an ILP transformer, and it doesn't have their standard primaries it must be a full-custom job. There's nothing else for it but to drive it gently on one winding and measure all the voltages to get the turns ratios. One possibility could be a transformer for a 100v speaker distribution system. possibly to go in the amplifier, possibly to go in a speaker cabinet. David
10th Apr 2018, 7:12 am | #12 |
The five pairs arn't the primary are they, you know the sort that go to a mains voltage selector? Though this doesn't sound right with just a two wire secondary. It sounds iffy for an audio tfmr too.Have you a variac or you can use a sig gen at around 5v.
Andy.
10th Apr 2018, 9:49 am | #13 |
The 5 pairs are also very low resistance per winding. I really would expect more than a fraction of an ohm for a mains primary.
I wondered about an audio transformer, either for a 100V line or an output transformer. But 5 windings on one side sounds odd. Somewhere I have an old 'labpack' power supply that gives out 0-20-odd volts AC in 0.2V steps (it's basically a tapped transformer). I can use that to put a couple of volts onto one winding and see what I get out. Safer than (just) a variac as the output is isolated from the mains. |
