Old 27th Jan 2018, 11:37 am   #1
sp10mk11
sp10mk11's Avatar
Default Aiwa TPR-210 Take Up Belt Question
Has anyone ever found a suitable replacement for the take up/FF belt on these machines, As it has no slipping clutch on this function rubber belts are no good as they grip too much.
Any ideas
Gary
sp10mk11 is offline
Old 28th Jan 2018, 6:54 pm   #2
camtechman
camtechman's Avatar
Default Re: Aiwa TPR-210 Take Up Belt Question
Hi Gary,
The thing about some Aiwa cassette machines, as well as R2R machines their designs were both innovative and at the same time a pain when they got old. I have come across other Aiwa machines that used a round belt that acted like a friction belt and then as a tension drive when a separate pulley wheel was swung across onto the belt in the FF mode. Is yours the round or square belt ?
Some Sony early cassette machines were made by Aiwa and they suffered FF problems.
When I die, please don't let my Wife sell my collection for the amount I told her I paid for it!
camtechman is offline
Old 29th Jan 2018, 9:58 am   #3
sp10mk11
sp10mk11's Avatar
Hello Tony
Looking at the hub on the capstan and the base of take spool it looks like it uses a flat belt with the FF tension wheel as you describe, this is the first time I have come across this arrangement, I tried a bit of stretchy elastic but this didn't work to well at all, I would like to get this going as it sounds very good, there is a guy on ebay selling 4 non working BASF machines 3 of which are the same as mine but I am thinking the belt is probably gone in those aswell
Gary
sp10mk11 is offline
Old 29th Jan 2018, 12:56 pm   #4
camtechman
camtechman's Avatar
I know this may sound stupid but, I can see from a pic on the web, that your Aiwa has a tape counter which should run off its own belt from either the take up spool or the rewind spool.
The reason for asking, is that Hitachi TRQ-299's are also notorious for having Play & FF problems (as well as Cue & Review). I have 8 of these and ALL of them suffer from the same problem; the counter belt shrinks & hardens and when replaced the problem is reduced.
It's worth checking the counter & its belt on your Aiwa just in case. It'll probably have no influence on your Aiwa but worth checking it out.
P.S. Don't buy any Hitachi TRQ-299's !!
Old 29th Jan 2018, 3:48 pm   #5
sp10mk11
sp10mk11's Avatar
Tony
What a nice looking machine the Hitachi is I could get duped by those smart looks, if only the Aiwa were so simple, yes the counter is driven off the REW hub, I don't even have it connected whilst this is going, I was sorting some belts that might be a bit loose and will give them a go tomorrow, or using a bit of grease/silicon so the belt slips in the play mode but doesn't slip when in FF due to the pressure roller................I am a dreamer me thinks.
I will take some pictures aswell
Enjoy your Hitachi
Gary
sp10mk11 is offline
Old 30th Jan 2018, 8:48 am   #6
camtechman
camtechman's Avatar
Gary,
Good luck, keep your chin up and, as like me with getting just one of my Hitachi TRQ-299's working, adopt the attitude "Oh well, It could be worse, it could be Russian !"
