Old 18th Jan 2018, 3:18 am   #1
Mandie H
Default Belling Champion no.81 heater
Would wood stove polish be suitable to revamp this heater? It's no. 81 but pre patent.
Is there anything else I should replace other than the cable and bulb?
Thanks.
ID:	155667   Click image for larger version
ID:	155668   Click image for larger version
ID:	155669   Click image for larger version
ID:	155670   Click image for larger version
Mandie H is offline
Old 18th Jan 2018, 1:10 pm   #2
Brigham
Default Re: Belling Champion no.81 heater
This is a splendid example of the Champion No. 81.
I find these earlier types much more 'satisfying' than the later pressed-steel '91' versions.
You may well have to change the flex; you don't seem to have the original!
Once you have the bottom off, you will find enough of the old flex to give you an idea what it looks like. Modern equivalents are usually black with yellow fleck, or black with white fleck. These don't look good with the predominantly white type currently used on electric irons.
The bulb may very well work. The heater almost certainly will.
Brigham is offline
Old 18th Jan 2018, 1:19 pm   #3
Herald1360
Herald1360's Avatar
Can't think why not. Both are cast iron and get hot!
More just a case of evicting spiders and general crud. Check internal wiring carefully for any signs of damage/dodgy insulation. If anything looks like asbestos, it probably is. DON'T disturb it, left to its own devices it won't hurt.
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 19th Jan 2018, 8:00 am   #4
Mandie H
Thanks.
Good job I like spiders
Had quite a lot of asbestos exposure over the years so I'll be vigilant. (Was brought up in a steel house with a blue asbestos roof?)
Will go order the stove paint now
Mandie H is offline
Old 19th Jan 2018, 8:05 am   #5
Mandie H
I have a later one with the pressed steel chimney. It is bronze in colour. I replaced the flex on that one with a grey iron flex.
I shall get a black iron flex for this one. The flex was cut when I got it. A friend bought a bundle of things at auction and the heater was included.
I shall replace the bulb with a 25W yellow bulb.
Mandie H is offline
Old 19th Jan 2018, 11:09 am   #6
Herald1360
Herald1360's Avatar
Put it in "Success stories" with a good picture when it's all pristine and glowing nicely
....__________
Old 20th Jan 2018, 10:51 am   #7
Brigham
You seem very confident that the bulb won't light!
I have various different bulbs in my examples. An ordinary 'fireglow' type gives spectacular results; you feel warm as soon as it's plugged in.
A ruby red bulb is nice in a bedroom. I have some ex-admiralty 'night vision' ones, and the deep red is very comfortable on a winter's night.
You can't go wrong with these, as far as heat is concerned. An all-time great design.
Brigham is offline
Old 20th Jan 2018, 2:57 pm   #8
Paul_RK
Paul_RK's Avatar
A nice scarce model too, I'm so glad you're not planning one of those dastardly conversions into the world's least efficient lamps!
With the early Champions I don't think many folk chose to pay the extra cost of the half-power switch and the lamp when buying smaller models. I have quite a colony now - a couple of 83As, a 2A and an 82A, an early and a very early (and lethal) No.1, and a pair of 79s - but haven't yet come across an 81A (which yours is, because of the optional lamp and switch).
Paul
Paul_RK is online now
Old 21st Jan 2018, 5:19 pm   #9
emeritus
Re the comforting warm glow, our cat used to bask in front of the red glow from the coal effect of our old Belling radiant electric fire, even when none of the elements were switched on.
emeritus is offline
