Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Offered and Wanted Messages > Service Manuals, Circuit Diagrams and Data Sheets Wanted
Service Manuals, Circuit Diagrams and Data Sheets Wanted If you need help finding service data post a message here. Please do not request or offer data that is available from www.service-data.com
Reply
Old 16th May 2024, 11:29 pm   #1
Julesomega
Julesomega's Avatar
Default SN76131N datasheet
Looking for some data on this dual audio preamp device. Nearest that Google search gets is a page on Radiomuseum.org which shows a photo of one and a schematic which equates them with µA739 and TBA231 which might be functionally the same but the pinout is different so this doesn't help me with my repair. Mine were mfd. from 1973–5.
- Julian
It's good here
Julesomega is offline   Reply With Quote
Old 17th May 2024, 12:24 am   #2
Julesomega
Julesomega's Avatar
Default Re: SN76131N datasheet
The datasheet for the TBA231 from https://cdn-reichelt.de/documents/da...TBA231_STM.pdf shows it is equivalent to the µA739 but that doesn't get me any closer to the TI device. A full datasheet is available from https://datasheetspdf.com/pdf-down/T/B/A/TBA231-ETC.pdf
- Julian
It's good here
Old 17th May 2024, 3:58 am   #3
FrankB
https://www.alldatasheet.com/view_da...hword=SN76131N
FrankB is offline   Reply With Quote
Old 17th May 2024, 5:02 am   #4
Terry_VK5TM
Terry_VK5TM's Avatar
By "the pinout is different", do you mean the offset spacing of the pins or the actual pin function?
Used to come across the offset pins often at one stage - just "re-adjusted" the legs of standard DIL devices to fit.
Terry VK5TM
https://www.vk5tm.com/
Terry_VK5TM is offline   Reply With Quote
Old 17th May 2024, 7:57 am   #5
Craig Sawyers
Craig Sawyers's Avatar
Originally Posted by FrankB View Post
The link says "no match", and offers a list of unrelated devices.
Craig
Doomed for a certain term to walk the night
Craig Sawyers is online now   Reply With Quote
Old 17th May 2024, 8:43 am   #6
Julesomega
Julesomega's Avatar
The pin functions of the SN76131N are different from the 'equivalents'.
I am also puzzled that the pins are staggered in my examples, despite having the package suffix 'N', I would have expected a different suffix. I am now wondering if the pins were bent before insertion, probably using the spacing device shown in the upper device in my picture.
- Julian
It's good here
Old 17th May 2024, 9:14 am   #7
Nickthedentist
Nickthedentist's Avatar
"QIL" or quad inline pin, as opposed to DIL.
Presumably easier people with fat soldering irons to deal with
Your RM link leads to their page for the Uher CG361 which has a circuit diagram attached. Might this be of slight help?
Nickthedentist is offline   Reply With Quote
Old 17th May 2024, 9:52 am   #8
Julesomega
Julesomega's Avatar
There's also a broken link on the RM page but I didn't see any more on the pinouts. Just looking now at the Goodmans 120 I am repairing and I see that it's a socket, not a spacer. RM doesn't have anything on the 120, and there is only one mention of the model on here. It's not worth the cost and delay of ordering a replacement from eBay so I aim to replace it with a more recent device, mounted dead bug style.
- Julian
It's good here
Old 17th May 2024, 10:17 am   #9
Nickthedentist
It's said (online!) that the 120 was barely more than a cosmetic rework of the 110.
The 110 used the µA739 mentioned upthread, also in a QUIL package, see snippet attached.
Any help?
Old 17th May 2024, 10:25 am   #10
Ted Kendall
That is certainly how it was perceived at the time.
Ted Kendall is offline   Reply With Quote
Old 17th May 2024, 11:43 am   #11
Julesomega
Julesomega's Avatar
Indeed! The only difference was the change from µA739 to SN76131N, along with the renumbering of all devices throughout the main amplifier stages
But not to worry, since tracing which pin is the output from the pre-amp I find that the channel levels are unbalanced but present, so I'm now looking for the fault in the main amplifier.
- Julian
It's good here
Old 17th May 2024, 7:50 pm   #12
Philips210
Julian, there was an article featuring the SN76131, "Disc Preamp", in the April 1975 issue of Elektor magazine. Elektor downloads used to be available on WRH website but no longer are. I have a copy that I can scan if required.
Incidentally, I think the same article was available from Elektuur, the Dutch version of Elektor in the December 1974 issue. I found this article (attached) from the circuitsonline.net site.
Regards,
Symon
Philips210 is offline   Reply With Quote
Old 17th May 2024, 8:08 pm   #13
jimmc101
jimmc101's Avatar
Any help?
At least some of the 1-10s were factory fitted with the SN76131.
If you look at my scribbles on that service manual, you'll see that I noted that IC2 was a SN76131.
(I replaced it because it suffered from popcorn noise on one channel.)
Jim
ps The original post is here
jimmc101 is offline   Reply With Quote
Old 23rd May 2024, 5:18 pm   #14
Julesomega
Julesomega's Avatar
Oh brilliant, Simon! The article says the LM 1303 has the same connections, but the gain, noise and stability are all slightly worse. A quick look on datasheetarchive finds the attached datasheet.
- Julian
It's good here
Reply
