#3181 | |
![]() Quote:
Since I was working in Cambridge, Max suggested that I come visit. It was actually the Summer shut down when the factory closed for at least a week. But Albinson was there, so I spent a cheerful hour or two talking to him. Lots of interesting stories of that conversation, but he absolutely confirmed that they did not listen to their products. They had no room or facility to do so. So I had it from the horses mouth, from the guy that designed the input of the 303, the FM3, FM4, 405 and possibly others before he shuffled off. Craig
Doomed for a certain term to walk the night |
#3182 | |
![]() Quote:
#3183 | ||
![]() Quote:
Anyway, I was not disagreeing with Quad not listening to their gear! That was well known. I was disagreeing that if an amp is well designed and measured then it will be erm.. right. I very strongly disagree with P J Walkers assertion that all well designed amps sound the same. That was my point. In fact I told him to his face what I thought of the 44 pre amp at the time. |
#3184 | ||
![]() Quote:
#3185 | |||
![]() Quote:
#3186 |
That wasn't the point being made. The use of NS10s comes when the broad characteristics of the mix are already set and the problem to be solved is the balance between voices competing in the midrange. For reasons which may or may not be concerned with the size of the midrange peak, the NS10s give the information the mix engineer needs to achieve this balance. At a milder level, I balanced a lot of stuff on LS5/8s, but I wouldn't have them at home...
#3187 | |
![]() Quote:
#3188 | |||
![]() Quote:
NS10's are awful things. They are used because 99% of other studios use them... they are expected to be there. They are to give an indication of how the mix will sound on dubious quality equipment such as is used by a majority of the public. Likewise Quad amps were not used in a few studios because of any specific qualities. I'll posit that Crown are/were probably the most widely used in fact. Quad was used in a small pond of usually UK studios, often (not always) for classical music, and especially by the BBC at one time. Quad attracts a very particular clientele ![]() Hobbies might include "this", horology, train spotting, supporting the National Trust and going to live classical concerts. This is "yer Quad man". Ownership of pipe and slippers not obligatory... Often a (classical) music lover rather than a hi fi enthusiast as such. To such people, if "equation 4b" "proves" that the amplifier is close enough to perfection to be indeterminable from perfection then no other claim will be given any credence whatsoever unless it comes in the form of mathematical "proof" that "equation 4b" was flawed! The above politics, with a small p, combined with the availability, VFM and reliability of Quad is why some studios, mainly in the UK, and the BBC, once used Quad amps. Last edited by Jez1234; 9th Aug 2023 at 7:22 pm. |
#3189 |
I may have said similar a few weeks back... not sure, but I find a wry amusement at occupying a no mans land between a rock and a hard place when it comes to hi fi
![]() Driven from every hi fi forum for fighting against the audiophoolery of magic fuses and enchanted wires of space cadet level subjectivism, I come here where I am then myself regarded as a maverick for insisting that there are subjective differences between amplifiers... You couldn't make it up! ![]() |
#3190 |
While studios at the top end of the market might have used something other than Quad, they were pretty much ubiquitous in the smaller studios that I've been in. They offer a good combination of sound quality and value for money. Their slightly restrained sound also helps tame the excesses of NS10s.
#3191 | |
![]() Quote:
#3192 | |
![]() Quote:
#3193 |
Not truly AUDIO phoolery, but i thought you chaps needed to see this...
https://offers.harmonipendant.com/harmoni/fbsale/?utm_source...RKGp79uVsW-IIINr0sBd_0UU9tbXIro49w0
David, G4YVM. |
#3194 | |
![]() Quote:
#3195 |
A correction to my previous post: I meant to write 'Quad 520'. They were all over studios in the 80s and 90s, for near-field duties. Not sure why I wrote 405, as I don't recall seeing them in studios!
NB - am still puzzled about James' quote! |
#3196 |
The 520 was certainly built for pro use. I've had a few in over the years. Sounds similar to 405 which is to be expected as topology basically the same.
I think James quote happened like that as he edited a multi-quote and inadvertently removed the OP name hence leaving it appearing to quote Knobtwiddler! |
#3197 | |
![]() Quote:
Did you feel better after delivering your opinion of the 44 to Peter Walker? I've used one domestically for forty years without complaint. As for Walker himself, whenever we spoke or corresponded he behaved like the gentleman he was. If you care to read his autobiographical notes as published in Audio Biographies you will note that he started out as an iconoclast, too... |
#3198 | |
![]() Quote:
#3199 | ||
![]() Quote:
![]() The right measurements... well yes that's what we need! I'd love to know what the right measurements are that could explain why amplifiers with exemplary performance by all the currently used measurements can sound so different! As for "Quad types" well today has been proof if any were needed that in antisubjectivist (to the extent of believing even all amplifiers sound the same) circles they are ones who believe everything required for the perfect amplifier was sorted out by Walker, Baxandall, Albinson, Williamson (Reg and DTN), Hafler etc by 1976 with the 405 and that if you think you can hear further improvement beyond the likes of the 33 and 303 in any other amplifier set up then you are imagining it. I'm surprised Gilbert Briggs name has not been brought up in "proof" that the perfect speaker had been designed by the late 50's as Briggs with H J Leak had demonstrated to many audiences that they couldn't tell the difference between Wharfedale and a live orchestra ![]() My decades of experience now in designing and building audio equipment, modifying it, repairing hundreds of commercial amps and listening to them with an eye to the topologies used all tell me differently. Beyond the point where amplifiers measure as "blameless" by the Doug Self criteria I've often noticed marked differences between the sound of amplifiers which appear to have no correlation with measurements. We'll have to agree to disagree ![]() |
#3200 |
I would expect all perfect amplifiers to sound the same.
But as nothing is ever entirely perfect, then how much of each possible imperfection can be tolerated before differences become noticeable? Different people have different threasholds. Music is an unruly signal to have to handle. Clipping happens. Simple steady-state sinewave testing doesn't explore an amplifier's behaviour in these circumstances. There are plenty enough amplifiers around which without putting ridiculous signals into them can be got into slew-rate limiting or taking unreasonably long to recover from a transient. So there are amplifiers which might look identical or even perfect under simplistic testing that can sound different with real world signals and usage applied. The fundamental problem lies in the assumptions behind simplistic testing being adequate. If a difference is heard, there ought to be a way to investigate the process causing it. Some perceived differences are psychosomatic, maybe a reaction to expenditure ![]() Mix in people without the background to understand technical issues, add in an absolute faith that there is no limit to the perception of their hearing. Oh, yes and the prestige of showing off expensive toys and you have a recipe for perpetual argument. I prefer to keep well clear of such people. I've designed quite a bit of stuff for myself, but although the RF stuff has been published, the audio stuff never has been, never will be. I've never owned any Quad equipment, but I've fixed a fair amount, and listened to it. I rove around surrounded by cherry wood and aniline leather. Never smoked a pipe or anything else. David
