Old 17th Feb 2019, 10:16 pm   #1
AD360 Rob
AD360 Rob's Avatar
Default Collaro Microgram. Heavy arm.
Evening all, just been given a collar microgram to look at for a friend. He said it's working but the arm feels wobbly. Investigation revealed that not only was the arm pillar loose (tightened the nut, cured) the arm is also very heavy. Indeed the spring for the weight adjustment appears to have nowhere to attach. I found an odd bit of metal inside the player which has holes and a right angled bend (a bit like mini meccano) but I'm convinced there's more missing. Can anyone help with photos of the underneath of the arm or possibly parts that I am missing? All costs met of course.
Rob
ID:	178581   Click image for larger version
AD360 Rob is offline
Old 17th Feb 2019, 10:19 pm   #2
AD360 Rob
AD360 Rob's Avatar
Default Re: Heavy arm
Forgot to mention, it's a later model with an ecl 82
Old 17th Feb 2019, 10:35 pm   #3
slidertogrid
slidertogrid's Avatar
I think there should be a little peg on one of the criss-cross mouldings . The spring then hooks onto the little strip with the holes in it the weight being then adjustable by hooking the strip onto the peg on the desired hole.
The peg often breaks off as the plastic seems to get brittle with age.
I have repaired them before by inserting a wire peg into the underside of the arm and re enforcing the new peg with araldite.
The arm adjustment is fairly crude and usually has to be set a little on the heavy side to get it to play without jumping or the sound sounding a little thin.
A lot of course depends on the cartridge used but not really a record player for your best records!
Rich.
slidertogrid is offline
Old 17th Feb 2019, 11:17 pm   #4
AD360 Rob
AD360 Rob's Avatar
Thanks for that Rich, I'll get the magnifier and strong light out tomorrow and see if I can determine where the peg was.
Rob
Old 18th Feb 2019, 12:06 am   #5
Techman
Techman's Avatar
I've got an example of that exact deck somewhere, so I can probably go and take a picture of what's under the back end of the arm if necessary.
Techman is offline
Old 18th Feb 2019, 12:47 am   #6
Techman
Techman's Avatar
Any good?
Techman is offline
Old 19th Feb 2019, 9:28 pm   #7
AD360 Rob
AD360 Rob's Avatar
Default Re: Collaro Microgram. Heavy arm.
That's fantastic, thanks Techman. I've araldited a pin in place of the plastic peg which is doing the job just fine but great to see exactly how the bracket fits (I've got it on the wrong way round and my cartridge wires aren't routed through the hole) Need to replace the motor mounts next and the cartridge as it currently needs a lot of pressure (in excess of 10 grams) to get a reasonable output even with a new stylus. I suspect the rubber has hardened also, there's evidence of the crystal starting to deteriorate (green deposits around the pins) It's a TC8 which are known for that and not being stereo compatible either. And, as Slidertogrid mentioned, it's not something I would want to play my decent records on
Old 20th Feb 2019, 1:43 am   #8
dalgwcobl
That turntable and arm unit were fitted to my first record player given to me when I was seven years old! I always thought they were of BSR origin, not Collaro. Maybe the TC8 made me think that.
What model was it then?
dalgwcobl is offline
Old 20th Feb 2019, 10:52 am   #9
Audio1950
You're right, that deck is a later BSR replacement. The original was a single play Collaro, hence the name .
Audio1950 is offline
Old 20th Feb 2019, 11:00 am   #10
peter_sol
Yes the only thing original is the case.
peter_sol is offline
Old 20th Feb 2019, 11:00 am   #11
Edward Huggins
The turntable unit is a BSR TU9 model from 1956. If the amplifier uses an ECL82, then you can fit a lighter, stereo-compatible medium output cartridge.
Edward.
Edward Huggins is offline
Old 20th Feb 2019, 7:22 pm   #12
AD360 Rob
AD360 Rob's Avatar
To be honest Edward, I did think it odd that a Collaro player would use a BSR cartridge plus, the arm is very reminiscent of a later BSR unit although it's been there a very long time. The owner doesn't want to spend heaps of money on it and it also needs motor mounts and a new on/off/volume pot plus some electronic work (hums) so has basically given it to me. I have found a goldring MX2M mono cart with mount for a reasonable price but am unsure if its stereo compatible. I like this cart because it is a turnover type so I wont have an ugly hole at the front of the headshell. Other alternatives are an Acos GP101 which is compatible but only plays LP unless you change the stylus (TC8 type) I also have a BSR X5M knocking around too.
Old 22nd Feb 2019, 12:17 am   #13
dalgwcobl
Well I'm glad i'm not going round the twist - a BSR TU9 it is! I'd fit the BSRX5M and forget about the hole in the front of the headshell. It would be stereo compatible and track at about 5-7 grams and be better than the MX2M which I think is only mono. The TC8, of any version, is pretty grim these days.
Old 22nd Feb 2019, 12:34 am   #14
ben
ben's Avatar
I'd go with a ceramic cart too. It will make the player more usable. You can always cover the hole with some suitably coloured adhesive tape or insulation tape or even a piece of coloured plastic!
Regards,
Ben.
ben is offline
Old 23rd Feb 2019, 10:07 am   #15
AD360 Rob
AD360 Rob's Avatar
I've had a dig around in my cartridge box and come up with a couple of unbranded stereo carts. I'll try these in the player as I'd rather keep the X5M for a better quality player (There's a Bush srp31D and a Hacker cavalier in the roundtuit pile). I'll let you know how it goes and how my search for compatible motor mounts goes too.
Old 23rd Feb 2019, 11:20 am   #16
Edward Huggins
In the last few years, we've recommended here the very capable BSR X5M many times as an ideal replacement stereo-compatible mono cartridge. I expect that UK stocks must now be at a very low level. That now leaves very little choice other than to use the still available Stereo arts and bridge them.
Edward.
Old 23rd Feb 2019, 5:19 pm   #17
Heatercathodeshort
Heatercathodeshort's Avatar
The case as mentioned is the only original bit! It dates from the 1939/46 78 only player with of course a Collaro deck. The original amplifier was quite a good unit employing EF37, CL33 and CY31 octal valves in a series circuit. They sounded good for an early portable [? it weighed a ton] record player. John.
Heatercathodeshort is offline
