17th Feb 2019, 10:18 am | #1 |
What is this tool for?
Morning peeps,
Just going through my tools and have come across this: sort of a Chuck with a lever on a ball. What is this tool called, and more interestingly, what is it meant to do? Never seen anything like this, no idea where it came from or why it is in my possession. Thanks, Stef.
Failing to prepare is preparing to fail ... |
17th Feb 2019, 10:29 am | #2 |
Re: What is this tool for?
Hi Stef, it looks like a larger centre finder/ wobbler.
Ed |
17th Feb 2019, 10:33 am | #3 |
I see, used in a pillar drill chuck fo finding the centre of a bore hole? Thanks Ed.
17th Feb 2019, 10:34 am | #4 |
Hi Stef, Mill, Drill or Lathe it will work on all of them.
Ed |
17th Feb 2019, 11:41 am | #5 |
To locate a surface on a workpiece relative to the spindle axis, the finder is run in the machine causing the ball to try to swing out on the lever under centrifugal force. Approaching the ball with a surface of the workpiece pushes the lever progressively nearer the axis of rotation until when it is almost on-axis it appears to be running steadily in contact with the surface. At the moment it is exactly on-axis the lever suddenly kicks over. The distance from the surface to the axis is now equal to the ball radius, which is accurately known (mine is 0.100") and can be entered into the readout as an offset.
17th Feb 2019, 1:01 pm | #6 |
I've got one of those, but I find it quicker and easier to stick a piece of fag paper (Rizla) to the workpiece and then slowly advance the workpiece onto the rotating cutter until it's whipped off.
17th Feb 2019, 5:13 pm | #7 |
The paper method was what we did at Rolls in the seventies. 'Izal medicated' on a dod of coolant liquid.... 2 thou.
See, there had to be a good use for the damnable stuff! David
17th Feb 2019, 5:23 pm | #8 |
Who the hell came up with the idea of making totally non absorbent toilet paper ?
I remember being lumbered with it as a kid during the great bog roll shortage during the 70s sometime. We had tto use something similar at school at one point as well
Chris |
17th Feb 2019, 6:42 pm | #9 |
Back on topic please
