Old 10th Oct 2018, 8:55 pm   #1
steve102
Default HMV 655 Armchair Radio
I've obtained an HMV 655 armchair radio. It’s a massive piece of kit measuring approximately 24” x 24” x 29” high and needs 2 people to lift it.
Most of the 2.3nf silver mica capacitors have been replaced in the past with Mullard mustards but there are still some original waxed paper decoupling capacitors that have melted and will definitely need replacing.
There are some circuit differences from the Broadcaster and manufacturers service sheets, including an extra tag board and capacitor near to V1.
I’ve decided to concentrate initially on restoring the cabinet while the weather is still good and to leave the electrical restoration for the autumn inter weekends.
It looked like the cabinet top had been used as a workbench at some point with deep scratches, drill holes and veneer loss. Fortunately, the damaged areas are responding well to treatment after first stripping the original cellulose finish which was flaking.
The rear wooden panel is missing but luckily the bookshelf is present so it should be relatively easy to make a replacement panel. Can anybody please confirm the correct height and thickness of the rear panel?
Steve
ID:	170683   Click image for larger version
ID:	170684   Click image for larger version
ID:	170685   Click image for larger version
ID:	170686   Click image for larger version
steve102 is online now
Old 10th Oct 2018, 10:25 pm   #2
MurphyNut
MurphyNut's Avatar
Default Re: HMV 655 Armchair Radio
There can only be a handful of these very unusual sets left, I was asked to restore (the cabinet) of one of these some 20 years ago. I remember it weighted a ton even with all the insides removed.
Clive
MurphyNut is offline
Old 12th Oct 2018, 8:29 am   #3
steve102
Your restored cabinet looks spectacular Clive, it shows off the contrasting veneers to their best effect.
I've found an earlier thread with a picture of the bookcase side posted by 350i which should enable me to scale the height of the wood panel.
Steve
Old 12th Oct 2018, 8:53 pm   #4
PaulR
PaulR's Avatar
The cabinet looks very well indeed. I can never understand why the makers used lovely veneers then covered them with thick brown lacquer.
Paul
PaulR is offline
Old 12th Oct 2018, 9:28 pm   #5
turretslug
turretslug's Avatar
That is a lovely piece of furniture, not to mention a rather fine receiver that must have been a source of fascination in its day. I wonder if these 655s survived because they doubled up as coffee/bedside table/bookshelf when lesser receivers simply became something broken that was in the way!
I can't help thinking that the veneer finish would have been as much appreciated in the '30s as today, perhaps the varnish was pale/near transparent originally but decades of sunlight and internal warmth oxidised it to the gravy brown typically seen.
turretslug is online now
Old 12th Oct 2018, 9:35 pm   #6
PaulR
PaulR's Avatar
I have a long case clock from the same era which has very similar veneers and the lacquer has stayed clear and shiny so that it looks much as it would have done when new.
Maybe the way the finish ages is a bit like rubber grommets and rubber covered wiring from the '30s. Some has aged very well and some has gone solid.
Paul
PaulR is offline
Old 13th Oct 2018, 8:36 am   #7
rontech
Very fine receiver "turretslug"! I had the Marconi console version and the HMV table version many years ago. They really came to life in the mid 1950's with a BSR autochanger plugged in.
Time flies like an arrow, fruit flies like a banana
rontech is offline
Old 22nd Feb 2019, 2:26 pm   #8
steve102
The bookcase section is now complete with a new back panel. I used 12mm hardwood ply which I bookmatch veneered in walnut.
ID:	178852   Click image for larger version
ID:	178853   Click image for larger version
Old 23rd Feb 2019, 9:58 am   #9
Kevin Hoyland
Hello Steve .
It is looking good, keep the good work up and I look forward to seeing the workings back in the case.
Kevin.
Kevin Hoyland is offline
