Old 1st Jan 2019, 1:54 pm   #1
Jolly 7
Default Old Ever Ready PP7 battery
Here is a recent carboot find, an unused PP7 battery. Unfortunately it is dead, but maybe the contents can be scooped out and replaced with six AAs. Not sure when this was manufactured.
ID:	175539   Click image for larger version
Jolly 7 is online now
Old 15th Jan 2019, 1:17 am   #2
RojDW48
RojDW48's Avatar
Default Re: Old Ever Ready PP7 battery
It can be done - I bought a 're-filled' LT/HT battery for an old portable valve radio a few years back and it looked the part.
'....don't go mistaking Paradise for that home across the road!' (Bob Dylan)
RojDW48 is offline
Old 15th Jan 2019, 8:59 pm   #3
Graham G3ZVT
Graham G3ZVT's Avatar
Was it rechargeable, particularly the HT side?
I'm not sure how to charge 10s of cells in series effectively.
Graham.
G3ZVT
Graham G3ZVT is offline
Old 15th Jan 2019, 9:27 pm   #4
Trifocaltrev
Trifocaltrev's Avatar
New PP7 batteries are available here
http://www.smallbattery.company.org.uk/sbc_pp7.htm
Trevor.
Trifocaltrev is offline
Old 16th Jan 2019, 10:50 am   #5
Brigham
My experience of the Small Battery Co. is that nothing is available that isn't readily available elsewhere.
I don't know if anyone else has had a more optimistic result?
Brigham is offline
Old 16th Jan 2019, 11:59 am   #6
NiCd or NiMH series strings can be safely charged at a suitably limited current. For long strings of Li cells the techniques used for EV batteries (typically 400V or so) could be used.
10 PP3s, the usual 90V string, could be charged individually and simultaneously with the harvest from a few boot sale raids
With a suitable screened and filtered design, it's perfectly possible to fit a low voltage highish capacity single rechargeable cell plus a couple of switching voltage converters inside an old battery case.
Herald1360 is offline
Old 2nd Feb 2019, 5:13 pm   #7
avocollector
I've used strings of el cheapo (one dollar shops) 9 volt batteries to power portable valve radios - think one had 5 for the 45+ ht although another one had 10 fitted for the 90v+; and D cells for the heater current. For this battery surely 3 or 4 el cheapo 9v in parallel would do the trick?? scavenge the snap connectors off the dud one.
avocollector is offline
