Old 18th Feb 2018, 3:21 pm   #41
Sideband
Sideband's Avatar
Default Re: Ekco T310 Restoration - complete novice
If you don't have any test equipment then you are making life very difficult for yourself...lots of frustration and randomly changing parts is not the best way forward. In answer to your last question...No, the output of the Aurora is only suitable for plugging in to the aerial socket. At the very least do you have a testmeter? If not I'd suggest you stop now and pay a visit to Maplin and buy a reasonable one, find out how to use it and then do some simple voltage checks. We can't help if we have no information ref voltages as the very least...
Sideband is offline
Old 18th Feb 2018, 6:00 pm   #42
Heatercathodeshort
Heatercathodeshort's Avatar
Please don't think we are being unhelpful Matt. We are all willing to help a novice but you must have some very basic tools with which to work with.
You can buy a simple digital meter from Ebay for less than £5 including postage. Rubbish you might think but I have a couple and they are accurate and ideal as a first meter. They will do all that is required to bring your Ekco into working order. Always make sure the chassis is NEUTRAL and check with a neon indicator screwdriver. Don't take things for granted.
A simple signal generator/tracer, the hand held type rich in harmonics is also a very handy tool. Again the outlay is low and once you get the knack of using it you will appreciate it's usefulness. No need for a big layout believe me.
Imagine trying to change a car wheel without a jack. OK it can be done but it makes for hard work.
If your nervous of getting a shock, wear a pair of surgical type disposable latex gloves. You can buy a box of 100 for just a few pounds.
This should be an easy one. The next move must be to measure the IF valve voltages and then to inject a signal at the required points. Good luck. John.
Heatercathodeshort is offline
Old 19th Feb 2018, 9:34 am   #43
Boater Sam
Matt, you may feel that we are not helpful but we need some basic info to go on.
If you just carry on guessing and replacing odd parts this renovation will get away from you. We have seen it happen many times.
It will be a shame to not get this set up and running.
Don't be worried about asking some one to come to you and hold your hand. I'm sure that some member near you would mentor you.If you feel that you would like help on a one to one basis, put a thread in the services required section of the forum.
Please don't take our comments as criticism, they are well meant.
Boater Sam is offline
Old 19th Feb 2018, 11:57 am   #44
Autozavod
Good morning gents,
please don't worry, I fully understand you are doing your best to help me, and I appreciate that.
I do have a multimeter (several) and an oscilloscope, I don't have a signal generator (I should have made that clearer).
My plan is to do a bit more reading in what to look for using the service manual and will be back to ask for more guidance when I'm ready to start more testing.
Cheers,
Matt
Autozavod is offline
Old 19th Feb 2018, 5:55 pm   #45
regentone001
regentone001's Avatar
one thing to check is that the channel numbers of the coil"biscuits" in the tuner match those on the knob they could have been moved around and I also remember that a lot of tuners only came with the biscuits for the area the set was to be used in
Steve
regentone001 is offline
Old 19th Feb 2018, 6:13 pm   #46
Freya
Freya's Avatar
I was actually thinking only this morning that the metal legend part of the knob could be installed incorrectly 180 degrees out also. As a suggestion also, try using the Aurora on CH.2 instead.
Stephen
Freya is offline
