Old 16th May 2025, 9:20 pm   #1
EyeFinkItzBroke
Default Ferguson Videostar 3V23 - rejecting tapes
Hi all. Sorry to join and come cap-in-hand, but I'm new to vintage tech and this VCR has me stumped.
It's a Ferguson Videostar 3V23 I picked up at RetroTechUK (first time attending). In fairness to the seller, it did work the first time I tested it. While trying to tune it in to a TV a few days later, it ejected the tape uncommanded. This was about one minute into playing. Now it won't accept tapes.
The rollers accept the tape into the basket and lower it down but immediately send it back up and spit the tape out. The belt is a little loose, but the basket does reach the bottom and clicks the microswitch underneath.
The lamp illuminates when switched on and I've cleaned the optical sensors with alcohol.
The loading guides/rollers make no attempt to withdraw tape from the cassette. Winding the loading mechanism by hand confirms a full range of movement with no binding. Interestingly, I can get it to lace the tape and present it to the head if I hold the play button down. The machine seems to get into a "tug of war" with itself trying the both load and unload the tape at the same time. I think this confirms the loading motor, belt, and mechanism are all fine though.
The eject lamp flashes when it's rejecting a tape. Not sure if that's significant. I did take the front panel apart in hope of a sticking eject button. No such luck.
Any help on where I go from here?
EyeFinkItzBroke is offline
Old 17th May 2025, 7:59 am   #2
George Cooper
Default Re: Ferguson Videostar 3V23 - rejecting tapes
Back in the day I worked on a good few of these machines, but I don't recall the issue you describe, you seem to have covered the basic checks fine.
This may be a tad off the wall but I have in the past had a few issues with both TV's and videos doing strange things when placed in a different place, namely are you running any high frequency fluorescent tubes anywhere near the machine, I have found that some of those tubes give off Infra Red interference causing all sorts of issues in the process. With VCR's I had noticed that a tape might be ejected if it gets overloaded with spurious IR. Just a thought, and easy to eliminate.
George Cooper is offline
Old 17th May 2025, 8:25 am   #3
vidjoman
If trying to make it work with the top off you may need to place a cover over the top of the housing to prevent stray light getting to the sensors.
vidjoman is offline
Old 17th May 2025, 12:33 pm   #4
EyeFinkItzBroke
Thanks for the suggestion. Same behaviour in both living room and office though. No fluorescent lights in either.
Old 17th May 2025, 12:39 pm   #5
EyeFinkItzBroke
I don't think ambient light is making a difference here as the behaviour is the same cover on or off. I'll keep this in mind though when testing any changes I make.
Old 17th May 2025, 12:40 pm   #6
EyeFinkItzBroke
Short demo video of the problem.
http://https://youtu.be/SE3Zr4r6k5w
http://https://youtu.be/3mOUgKnFAXw
Old 17th May 2025, 1:19 pm   #7
agardiner
agardiner's Avatar
Sounds like the machine doesn't properly accept the tape. First thing to check is the loading belt, if it is loose then it might not complete the loading, resulting in rejection of the tape. Also perhaps give the mode switch a little squirt of contact cleaner.
As vidjoman says, stray light entering the sensors with the top cover off will also cause this problem which can result in red herrings when trying to troubleshoot.
agardiner is offline
Old 17th May 2025, 4:59 pm   #8
John123
Agreed, the fault seems pretty immediate so most likely to be loading-related. I'd recommend you try and source a 3V23/ HR7700 belt kit from somewhere and do all of them.
The cassette carriage comes out relatively easily, though can be a bit of a fiddle to refit! Just try not to force anything, or snag the flat-flex going to the indexing head.
Regards,
John
John123 is offline
Old 17th May 2025, 8:32 pm   #9
dj_fivos_sak
I seem to recall this happening intermittently on my AKAI VS-10 (same machine). I didn't investigate the cause as it was only rarely happening on mine. Sensing the action of a cassette being pushed in is done by an optical sensor, but sensing of the cassette (carriage) going down is done by a leaf switch or micro switch, located at the right-hand side of the deck, underneath the carriage. I would suggest cleaning that switch and testing it with a multimeter for continuity. If the switch is OK then a syscon fault should be suspected, either a logic problem due to a failed IC or the signal isn't reaching the microprocessor.
Fivos
dj_fivos_sak is offline
Old 20th May 2025, 2:53 pm   #10
Spec-chum
I could be wrong but I seem to recall these machines would either eject the tape, or switch to standby if the timer switch was in the on position and the clock not set.
Spec-chum is offline
Old 22nd May 2025, 1:40 pm   #11
EyeFinkItzBroke
Update on this: I ordered a belt kit and replaced all belts. No dice - still rejects tapes.
I have managed to get it play a tape twice since. Both sessions were interrupted by an uncommanded eject followed by the now familiar behaviour of rejecting tapes. I think this is diagnostically significant as the loading mechanism wasn't active at the onset of the problem behaviour, thus thinking of this as a loading failure is maybe taking the symptom too literally. Would failure in another system prompt an eject?
Only other observation is that the machine seems to have a higher chance of accepting a tape from cold (i.e. when the machine hasn't been used previously that day). Once the ejecting behaviour starts, it repeats until the machine is left for a significant period. Possibly a thermal trigger to the problem?
Old 23rd May 2025, 10:01 am   #12
Welsh Anorak
Welsh Anorak's Avatar
Have you tried getting it going then disconnecting the front panel - or specifically the eject switch? Try the easy option first!
Glyn
Welsh Anorak is offline
Old 23rd May 2025, 1:03 pm   #13
John123
Yes definitely look for anything obvious before delving deep into the inner workings of this rather complex beast. The only relevant faults I could find are listed below, but some are likely to be red herrings:
Cassette loading motor unloading all the time:
X10 s/c; X22 o/c on mechacon board
Rejects rewound tape when inserted:
X4 servo 2 panel (inside)
Tape unloads after playing for 2-3 sec:
Photo interruptor (under take-up reel)
'Tape-guard' circuit coming into operation:
Drum pick-up head o/c.
Hope that helps!
Regards,
John
John123 is offline
Old 26th May 2025, 9:04 pm   #14
EyeFinkItzBroke
Couple more suspects ruled out. I tried the suggestion of programming the date/time. No change in behaviour. I also tested for actual continuity in the micro switch under the cassette carriage. No continuity when carriage raised. Continuity when carriage lowered. Results appear consistent with a functioning switch.
Front panel wiring soldiered in at the panel end. Followed the wiring as best I could back to a pcb plug, but it's a real rats nest of wires in there and the yellow wire used for the eject button is not unique. Disconnecting disabled the function lights for eject, play etc., so I think I pulled the right one. No change in behaviour.
The more we get into testing circuitry, the more I will need my hand holding.
Copyright ©2000 - 2026, vBulletin Solutions, Inc.
Copyright ©2002 - 2026, Paul Stenning.
