Old 25th Feb 2025, 9:59 pm   #1
Joe_Lorenz
Joe_Lorenz's Avatar
Default Tempting find: 1965 Graetz Landgraf 920
Hello,
as my wife does some clear out of her sewing and needle work room we have dug out this Graetz b/w TV set. I had totally forgot about it, must have been sitting there for the last 20 years or more. The cabinet has two or three dings but is otherwise in very good condition.
I have had no plans to restore a 1960s TV any more, but I got to admit this one is tempting. Please see the photos: It looks quite service-friendly built, lots of good quality components, all original valves present, and that A59-12W crt has had a good reputation those days. As of 1965 it was quite modern with a partly transistorized tuner, modern PCF 200 and PFL 200 valves but not-so-modern PL 504 - PY88 - DY 802 line output and ht stage. I must have dozens of these in stock. I am afraid a weak point will be the "Wima" cracked capacitors.
I'd regret to let it go to the skip, but I think to be able to fix it I'd have to dig out the wobbulator, test pattern gen, maybe tube juvenator and so on. Any opinions are very welcome!
ID:	311336   Click image for larger version
ID:	311337   Click image for larger version
ID:	311338   Click image for larger version
ID:	311339   Click image for larger version
Joe_Lorenz is offline
Old 25th Feb 2025, 10:01 pm   #2
Joe_Lorenz
Joe_Lorenz's Avatar
Default Re: Tempting find: 1965 Graetz Landgraf 920
Some more photos:
ID:	311341   Click image for larger version
ID:	311342   Click image for larger version
ID:	311343   Click image for larger version
ID:	311344   Click image for larger version
Old 25th Feb 2025, 10:07 pm   #3
Joe_Lorenz
Joe_Lorenz's Avatar
Even more photos:
ID:	311346   Click image for larger version
ID:	311347   Click image for larger version
ID:	311348   Click image for larger version
ID:	311349   Click image for larger version
Old 26th Feb 2025, 1:10 am   #4
Maarten
Nice set and good photography.
After replacing the critical capacitors, I would just switch on for some hours and watch before evaluating if the tube should be rejuvenated.
Weren't the PL504/PY88/DY802 the most modern options available before transistorisation?
Maarten is offline
Old 26th Feb 2025, 6:38 pm   #5
high_vacuum_house
high_vacuum_house's Avatar
Good evening,
This looks a nice and viable project. It all looks complete and no signs of damp which is a big bonus.
I would first warm up the LOPT by passing some current through the overwind by EHT rectifier anode to the line output valve anode. say enough for a couple of watts from a bench power supply for several days to ensure no damp remains.
Snip out the mains RF bypass capacitor if it has one and bring it up slowly. As long as nothing else has been adjusted, you should hopefully get some sort of a raster on the screen.
Then a matter of going through the time base oscillators, video and audio stages!
Christopher Capener
Interests in the collection and restoration of Tefifon players and 405 line television
high_vacuum_house is offline
Old 26th Feb 2025, 9:49 pm   #6
Joe_Lorenz
Joe_Lorenz's Avatar
Indeed I am inclined to clean the set a thoroughly, vacuum off all dust and start as suggested. It is simply too good to bin!
No valve has marks of intense use. Particularly those PL 504 and PY 88 tend to show brownish shaded areas (caused by x-rays?) after some years, and here I didn't see that anywhere.
Joe
