Old 27th Apr 2025, 1:36 am   #1
hugocarmo
Default Panasonic TX-24A1UN CRT Sound and Input problem.
Hi.
I´ve been given an old CRT from Panasonic, it´s almost new, it was storaged and almost not used since bought.
It is imaculate inside, almost no dust or debris inside.
The picture is good, but I have no left sound channel, I tried all the inputs, outputs, even on headphone jack. In AV2 I hear sound from right channel but no image, on tv tuner only right sound channel, the same for AV1.
So I started to look for a service manual, I found one, and started from the beginning.
Most of the times the caps are the problem so I orderer all the caps for all boards, wich I replaced, one by one, not all because I misunderstood some of them and ordered polarized when they were non polarized, of course those I didn´t replaced, but I can say that I have 70% of all boards, with new capacitors, all almost nichicon.
Well, the problems remains, no left sound channel, no image in AV2, only on AV1...
Some of You have any experience with this model? It´s a Alpha 2 Chassis, I will upload some pictures and the service manual.
Thank You all in advance,
Hugo from Portugal!!
Service manual GDrive link https://drive.google.com/file/d/1TU7iXHmg4P0YWFN9Y53PmxeDpy0ohcTl/view?usp=sharing
ID:	313708   Click image for larger version
ID:	313709   Click image for larger version
ID:	313710   Click image for larger version
ID:	313711   Click image for larger version
hugocarmo is offline
Old 27th Apr 2025, 9:06 am   #2
simpsons
Default Re: Panasonic TX-24A1UN CRT Sound and Input problem.
Hi Hugo
Looking at the UK TX24A1 version, this is quite a sophisticated TV which requires the original remote control and copy of the Operating Manual to access the many functions and options.
Do you have both?
Chris
simpsons is offline
Old 27th Apr 2025, 12:16 pm   #3
Welsh Anorak
Welsh Anorak's Avatar
It's unlikely capacitors would have been to blame here.
Chris is right - it could be something as simple as the balance control being to one end. If not then I'd be looking at the AV switching chip.
Glyn
Welsh Anorak is offline
Old 27th Apr 2025, 12:42 pm   #4
Maarten
The sound signal should be traceable.
Maarten is offline
Old 27th Apr 2025, 1:25 pm   #5
hugocarmo
Originally Posted by simpsons View Post
Hi Hugo
Do you have both?
Chris
Hi Chris.
Thank You for your answer.
I don´t have the original remote, but I found one and aleady bought it, I´m waiting for it to arrive from Germany.
The Operating manual I can´t find it anywhere, only the service manual.
I´ll try with the original remote when it arrives.
Thank You.
Old 29th Apr 2025, 8:58 am   #6
simpsons
Hi Hugo
To see the functions of the original remote control, download the Panasonic TX24A1 Manual (User Guide).
This is the UK version of your set and whilst it may not include some of the specific adjustments for example, the multi system capability, for audio, the dual mono, bilingual mono, Stereo sound channel selection, etc, etc, are shown.
Chris
simpsons is offline
Old 29th Apr 2025, 1:14 pm   #7
hugocarmo
Hi Hugo
Chris
Thank You Simpsons.
I downloaded it, now I´m expecting the remote to arrive for further testing.
Best regards,
Hugo.
Old 20th May 2025, 10:06 am   #8
hugocarmo
Hi.
I have some updates about this repair.
As I said I was waiting to receive the original remote that I found online.
After receiving it it didn´t work.
I opened it, tested all components, replaced the two capacitors, and came to the conclusion that was the crystal ressonator that was bad.
It is a CSB420P, I ordered one and after replacing it, the remote started to work perfectly!
The remote has some tracks that are in bad shape, I scraped the lacker and applied new one, I think it will last for a few years!!
Now, the sound problem... I ordered some IC´s, STK4392, AN5836, TDA3803A, M51321P, and PCD8582DP, I found them cheap so ordered all.
After replacement of all of them, I resolved the sound problem.
Now I have sound on both channels, this tv has a great sound quality indeed!
But the AV2 scart input remains with the problem that only sound is heared.
The screen is gray with no picture at all, only sound.
Something curious, when I have AV1 connected if I go to any channel in tuner the image is the same as AV1, is it normal?
I post images and a video in the end of the post.
Thank You very much!
Hugo.
https://vimeo.com/1085978165?share=copy
Name:	Screenshot 2025-05-20 144415.jpg
ID:	314818   Click image for larger version
Name:	Screenshot 2025-05-20 144433.jpg
ID:	314819   Click image for larger version
Name:	Screenshot 2025-05-20 144452.jpg
ID:	314820   Click image for larger version
Name:	Screenshot 2025-05-20 144513.jpg
Last edited by Cobaltblue; 20th May 2025 at 1:46 pm. Reason: external links removed
Old 20th May 2025, 4:43 pm   #9
marceljack
This as well as no picture on AV2 is probably due to a problem in the AV switching (video circuitry always connected to AV1, even when in AV2 or tuner position).
Is there not a connection between two pins (due to an excess of solder for example)
marceljack is offline
Old 20th May 2025, 8:35 pm   #10
hugocarmo
Hi marceljack.
I think not, I replaced the AV switching chip and the problem remains.
But let me explain better, if I connect the antenna I can tune analog TV channels.
Thank You.
Old 21st May 2025, 8:25 am   #11
Welsh Anorak
Are you sure that AV2 isn't configured electronically for RGB? Some were.
Glyn
Old 21st May 2025, 8:30 am   #12
hugocarmo
I can try connecting another type of equipment to AV2, maybe a vcr or a PS2 to test.
Thank You.
Copyright ©2000 - 2026, vBulletin Solutions, Inc.
Copyright ©2002 - 2026, Paul Stenning.
