3rd Apr 2020, 12:58 am | #1 |
Can I use rechargable batteries in a vintage record player? National Panasonic SG-760
Hello.
I wonder if anyone knows if I can put rechargeable batteries into my old battery operated record player, it is a National Panasonic SG-760F, it says it takes D size flashlight batteries. I'm not positive but think my player is from the 60's. I have had a look on Google but cannot find my answer. Hopefully someone can help me with the answer. Thank you so much. |
3rd Apr 2020, 10:17 pm | #2 |
Re: Can I use rechargable batteries in a vintage record player?
Generally speaking, yes, you can use standard-size rechargeable batteries in place of disposable ones.
I've used some in a 1970s Sanyo portable record player without any problems. In my case, I used AA rechargeable batteries inserted into AA to D size adaptors instead of actual D-size rechargeable batteries which are available, but more expensive. I already had some AA rechargeable batteries and an AA battery charger, so I didn't want to buy another charger and set of batteries. A few points to note: Regular high-capacity Ni-MH rechargeable batteries lose their charge quite rapidly when not being used. You might find they are flat after about 3 months, and you'll have to spend a few hours recharging them again before you can use them which is inconvenient if you only use your record player infrequently. There are now pre-charged, ready-to-use rechargeable batteries available which can stay charged for a year or more. (Also called Hybrid or Eneloop batteries) These may be a better buy. Rechargeable batteries can supply a lot more current than the old zinc-carbon batteries that your record player was designed for. This is normally a good thing, but in case a short-circuit fault develops in your appliance, the rechargeable batteries could become very hot, causing burns or damage. If the record player does not work and the batteries feel hot, remove the batteries immediately. Another point about rechargeable batteries: they usually go flat very suddenly without much warning. For this reason they are unsuitable for devices such as smoke alarms where failure could endanger life. |
3rd Apr 2020, 11:06 pm | #3 |
These GP brand Ni-MH D-cells from CPC are probably as good as you will get at the price -
https://cpc.farnell.com/gp-batteries...mah/dp/BT06290 |
3rd Apr 2020, 11:54 pm | #4 |
The only item I have met where the instructions specifically said not to use rechargeable batteries to prevent damage is a Mecabltz electronc flash gun I bought in 1968. It was mentioned in a contemporary photographic magazine review of such flashguns that they relied on the internal impedance of disposable batteries to limit the inrush current, and that, although the then-available rechargeable batteries (nickel cadmium) had a lower voltage than disposable ones, their much lower internal impedance could deliver enough surge current to cause damage. I can't see this being a problem with a record player, other than, as mentioned above, if a short circuit fault occurs.
4th Apr 2020, 9:13 am | #5 |
Some things come with plastic tubes which you slip over the battery before installing it. These provide additional insulation if the coating on the battery itself becomes damaged.
Stuart The golden age is always yesterday - Asa Briggs |
6th Apr 2020, 2:03 pm | #6 |
Thank you so much everyone, perfect.
I will get your recommended batteries Boulevardier, thank you. Sorry I have one more question to do this with post if someone can again help please. Can anyone let me know/recommend what battery charger I need to buy to use with the batteries below? I'm really sorry I am clueless but hopefully will learn a bit off this forum. It is really interesting. Thank you again in advance. https://cpc.farnell.com/gp-batteries...mah/dp/BT06290 |
6th Apr 2020, 3:05 pm | #7 |
Worth looking at chargers at CPC online if you're ordering the rechargeable batteries from them. You might have a job finding one that will charge all your D-cells at the same time, and you may have to charge them in two batches.
Mike |
6th Apr 2020, 4:33 pm | #8 |
Unless you bought their own branded Ni-Cd pack that it. For some reason, they didn't have the same problem as singles in the AA case.
6th Apr 2020, 5:54 pm | #9 |
A word of warning , you need to fit a suitable fuse in line with the battery I would think a 1 amp would be ok . protection, should a fault develop it won't catch fire Mick.
6th Apr 2020, 6:26 pm | #10 | |
Could be just a cynical ploy, or maybe the own brand pack had a suitable resistor in series with the battery? Wouldn't be difficult to simulate anyway- just measure the peak current from a set of nearly new alkaline AAs, then experiment a bit with resistors in series with your NiCd (starting high!) to get a similar peak current.
6th Apr 2020, 8:31 pm | #11 |
Looks like being an expensive project - do you really need it to run from battery power?
I believe it has sockets for a 9 volt external power supply?
George |
6th Apr 2020, 11:48 pm | #12 |
Rechargeable batteries are more expensive to buy, but better value in the long term if you use them frequently.
Running something directly from the mains (using a mains adaptor if needed) is almost always cheaper than using batteries. The only exception I can think of is electric clocks, which cost slightly more to run each year than the price of a disposable battery in a quartz clock. Supposing you buy the suggested D batteries https://cpc.farnell.com/gp-batteries...mah/dp/BT06290 You'll need 3 packs at £9.30 inc VAT, that's £27.90 so far. Then you'll need a charger, such as this one: https://cpc.farnell.com/gp-batteries...imh/dp/BT06299 Total so far: £27.90 + £19.43 = £47.33 For about the same price you could buy 3 packs of 10 disposable alkaline batteries : https://cpc.farnell.com/gp-batteries...k10/dp/BT00064 This would give you 5 sets of 6 batteries, so you would start saving money after you had used all of these. There is one snag, and that's if you buy the above rechargeable batteries and charger, you can only charge 2 or 4 batteries at a time. Your record player uses a set of 6. It will take 12.5 hours to recharge the first 4 batteries, then another 12.5 hours to recharge the other 2 in the set, during which time you will be unable to use your record player. You could buy another set of rechargeable batteries to keep in reserve, or an extra charger to shorten the total charging time, or accept the delay while the batteries are being charged. As I mentioned earlier, I opted to use the more common and cheaper AA size rechargeable batteries with adaptors. At one time, Poundland sold packs of one AA rechargeable battery with D size adaptor for £1. They even sold 2xAA battery chargers (USB powered) for £1 as well. They no longer seem to stock these, but they still sell packs of 2 AA cells for £1. Lidl supermarkets sometimes have special offers on rechargeable batteries of different sizes. AA rechargeable batteries and adaptors are available online, e.g. Amazon : https://www.amazon.co.uk/Size-Batter.../dp/B0092XYLP6 Although they are a lot cheaper, the catch with using AA batteries is that they hold less charge, so they'll run out faster and need more frequent charging than D cells. This is particularly true of the Poundland AA cells, which have a relatively small capacity. Nonetheless, I've used them in my Sanyo briefcase portable record player. They're fine for occasional use. As a bonus, I can use the AA batteries in other gadgets and save even more money. |
7th Apr 2020, 9:23 am | #13 |
Manufacturers often said do not use rechargeable batteries on items like flash guns and radio microphones because the performance will be impaired due to the voltage of the batteries being significantly lower (20% less).
On a battery operated record player I have the speed control has to be turned up fully because I am using rechargeable batteries. Mike |
7th Apr 2020, 11:00 am | #14 |
Sometimes Lidl have their own Tronic branded Ni-Mh batteries and chargers, cheap @~£3 a pack (2xC/D 4xAA/AAA) and their intelligent chargers are good too.
7th Apr 2020, 11:39 am | #15 |
In my experience some AA rechargables are slightly larger than alkaline AA's. So you'd need to check the fit.
The Waves That Rule Britannia |
7th Apr 2020, 11:49 am | #16 | |
poppydog |
7th Apr 2020, 1:13 pm | #17 | ||
7th Apr 2020, 2:34 pm | #18 | |||
7th Apr 2020, 5:19 pm | #19 |
Also, the general public were not as aware as we were/are of the mixed behaviours of rechargeable cells, possibly resulting in unwanted callbacks.
7th Apr 2020, 10:49 pm | #20 |
i have several battery players and always stuck to Duracell batteries and find they last ages ranging from 60 hours and upwards, with volume at a reasonable level
