18th Mar 2020, 12:28 pm | #21 |
Re: Lafayette HE-40
Reading previous posts suggests that a mains transformer has been fitted? If so the wiring to this should be one of the first things to check. You should not assume that the set worked in previous ownership.
18th Mar 2020, 12:32 pm | #22 |
Re: Lafayette HE-40
That BFO circuit was also used in the Hallicrafters S120, similar looking receivers in many respects.
Lawrence. |
18th Mar 2020, 12:32 pm | #23 |
Re: Lafayette HE-40
There's been a lot of posts crossing with my edits to 11:09 (post #17) one! Hope not too much confusion as a result!
18th Mar 2020, 12:37 pm | #24 | |
Re: Lafayette HE-40
Numbers are very difficult to read in the schematic. The set was plugged into the Lamp Current Limiter, and it looked OK when powered on - nothing super bright, just medium brightness. When I replaced the burnt electrolytic caps. it was receiving very well. I liked the tone and, it was fairly sensitive. Then the BFO stopped working, and I opened it up again to see why the BFO is not working. I probed here and there with my DMM to check continuity and ohms, and the resistor on the BFO was starting to burn with live flames like BBQ. I couldn't believe what was happening in front of me.
ORAWA = Old Radios And Wire Antennas |
18th Mar 2020, 12:43 pm | #25 |
Re: Lafayette HE-40
Aargh! Should have said C12 not C5! It's the furthest left capacitor on the circuit diagram and is 0.05uF. A 47nF safety suppression type capacitor would be the suggested replacement.
18th Mar 2020, 12:48 pm | #26 |
Re: Lafayette HE-40
Yup, I noticed that cap, it was piggybacking a resistor and sitting on a valve pins.
Could it be replaced with a poly capacitor of 630V 47nF?
18th Mar 2020, 12:54 pm | #27 |
Re: Lafayette HE-40
C21? across the mains supply needs to be a Class X component. It can be snipped out for the present. That's assuming it wasn't removed when the mains transformer was fitted.
18th Mar 2020, 1:18 pm | #28 | |
Re: Lafayette HE-40
So far as I can make out the resistor that burnt up that you've described is R5 on the schematic, it's value being given as 5k. Lawrence. |
18th Mar 2020, 1:27 pm | #29 |
Re: Lafayette HE-40
I seem to remember that UK HE40s had a 240 - 120v transformer installed but not sure if it was an auto transformer. I had one once but I can't be sure my mind isn't playing tricks on me! Kind regards Dave |
18th Mar 2020, 1:42 pm | #30 | ||
Re: Lafayette HE-40
Would it be not the R7 300R? R5 at 5K - is it the one?
18th Mar 2020, 1:58 pm | #31 | |||
Re: Lafayette HE-40
Yes, R5 (5k) so far as I can make out.....as per these photos: Lafayette HE 40: https://civil.trcvr.ru/wp-content/up...te-HE-40-3.jpg Hallicrafters S120: https://antiqueradios.com/forums/vie...p?f=5&t=197286 Note: The Hallicrafters S120 uses a 470 ohm resistor for the resistor that's designated as R5 (5k) in the Lafayette HE 40. Lawrence. Last edited by ms660; 18th Mar 2020 at 2:18 pm. Reason: addition |
18th Mar 2020, 2:05 pm | #32 | |
Re: Lafayette HE-40
Give or take all the confusion I may recently have created.... C12 0.05uF is connected between HT- (ideally mains neutral, but could be mains live) and the receiver chassis. The chassis is used for the front end RF ground and also connects to the antenna ground external connector. It should be a Y-class part. Unfortunately it's got a functional (RF ground) role as well as being connected between mains (potentially mains live) and user accessible metalwork so it can't just be snipped out. C21 0.02uF is connected across the mains supply after the single pole switch and should be an X-class part. It may be snipped out without affecting function though this might degrade the set's resistance to mains borne interference. Functionally either could be replaced by a 1000V dc or higher polypropylene film type but these types, whilst arguably better than the original parts, will not meet present safety standards required for mains connected capacitors.
18th Mar 2020, 2:24 pm | #33 |
Re: Lafayette HE-40
Thanks for your confirmation. R5, 5K resistor for the burnt resistor on the BFO pot. I am not sure if there is one of the value in my parts drawers. Will search for it.
With the 12AV6 valve unplugged, the set will not come on. When it is plugged in, the set will come on, but the 12AV6 is not lighting up, and there is no signals heard. There is some hum and tiny little signals of MW stations on all band selections. Even when the main tuning dial turned, it doesn't change anything. When the set is powered off, the 12AV6 is warm all around the glass. I am a bit scared of probing anything on this set with DMM, because it might set on fire on something. There is continuity between the heater pins 3 and 4. The pin 2 (cathode) has no continuity with any pins. There is a mains transformer on the chassis, and it looks like single coiled one. - no primary and secondary type. Just one chunk of coil in the core looking like audio transformer.
ORAWA = Old Radios And Wire Antennas Last edited by ORAWA01; 18th Mar 2020 at 2:29 pm. |
18th Mar 2020, 2:27 pm | #34 |
Re: Lafayette HE-40
See post #11.
18th Mar 2020, 2:48 pm | #35 |
Re: Lafayette HE-40
No AC volts on the pin 3 and 4.
So the 12AV6 is gone bad?
18th Mar 2020, 2:50 pm | #36 | |
Re: Lafayette HE-40
18th Mar 2020, 2:55 pm | #37 | |
Re: Lafayette HE-40
As an additional check you could measure the volts across the other heaters and lamps.
18th Mar 2020, 3:00 pm | #38 | |
Re: Lafayette HE-40
After that, it was not lighting up. The only pin has voltage out is the pin 5, about 4V AC. Do you mean to check the other valves heaters and the tuning dial lamps voltages?
18th Mar 2020, 3:15 pm | #39 | |
Re: Lafayette HE-40
Should be fine. If you're worried, just use a couple of 10K in parallel or a 270R or 330R in series with the 4k7.
18th Mar 2020, 4:54 pm | #40 |
Re: Lafayette HE-40
Thanks.
What are the substitute valves for 12AV6? I think the tube is defective, which makes the set not receiving any signals. It has noise and weak MW signals, but not tuning for the right signals on the bands. I have a few old valve sets, and trying to find the tube equivalent to 12AV6. Some valves I see in the other sets are, 6AU6
ORAWA = Old Radios And Wire Antennas Last edited by ORAWA01; 18th Mar 2020 at 5:08 pm. |
