Old 22nd Mar 2020, 11:10 am   #21
Radio Wrangler
Radio Wrangler's Avatar
Default Re: Low distortion oscillator
Originally Posted by Craig Sawyers View Post
Back in the day I built a Texan (as I suppose other here did). That used 741 and 748 opamps which were an eye popping 60p each (getting of for a tenner in today's money). We've come a long way since then.
I've never built a Texan. I did fix plenty of them for people who ran into trouble, back in my student days.
Though you couldn't really call it hifi, the Texan made a lot of people happy for several years. All the "Um, could you have a look at this thing I've been making..." preambles served as aversion therapy for me. So I built a Mullard blue book 25 watter for a friend, and the later edition 50 watter for myself. My disc preamp was from Hugh Walker's mixer articles in WW. After that I went with own-designs.
I wonder just how many Texans were built?
I guess there are some that ran into problems still hidden out of mind in cupboards around the country.
Radio Wrangler is online now
Old 22nd Mar 2020, 11:19 am   #22
Electronpusher0
I built a Texan, it did work and eventually sold it on. I also settled on a Mullard blue book 25 Watter which I used for many years.
For a while it was used at work, we sold some very small LVDT tranducer amplifiers that ran on 240V, we were delighted when we won an order from the Swedish nuclear industry for a signicant quantity. We were less delighted when we saw the testing specification.
One requirement was to vary the mains frequency over a range (I think it was 50Hz +/- 10 or 15%)
I connected a signal generator to my Mullard amp and drove a 6V transformer in reverse to give the required voltage.
It certainly worked but would blow the output transistors occasionally. Fortunately my firm paid for a plentiful supply of replacements.
Peter
Electronpusher0 is offline
Old 22nd Mar 2020, 1:19 pm   #23
Craig Sawyers
Craig Sawyers's Avatar
Mine worked fine. Built the preamp as an individual board first, and then added a second board housing the power amps. It never missed a beat.
Gave it to my dad (long time gone now), then powered our kitchen system here for a number of years, and now it resides in my loft. I'm betting if I power it up it would work perfectly. Well as perfectly as a 741 ever did!
Craig Sawyers is offline
Old 22nd Mar 2020, 3:06 pm   #24
daviddeakin
daviddeakin's Avatar
If you only want one fixed frequency, one of the easiest approaches is to build a basic sinewave oscillator without worrying about ultra low distortion, then filter the heck out of the signal. Keep filtering and re-amplifying (with decent opamps of course) until you reach the residual distortion level you're aiming for.
daviddeakin is offline
Old 22nd Mar 2020, 3:41 pm   #25
Radio Wrangler
Oddly enough, if you are trying for very low distortion, making a filter which doesn't produce its own distortion is as big an undertaking as a low distortion oscillator.
If you build a passive L-C filter you run into problems with the linearity of magnetic cores and to a lesser extent, even with capacitors (which is where we circle back to Bateman's articles and the purpose of his work)
If you build an active filter, you're back with the issue of the linearity of amplifiers whether discrete or monolithic.
At least you don't have to juggle with the business of stabilising oscillator amplitude at the same time. I did go down the filter route when I needed very low distortion (for the era) sources when I was playing with power amp design. I needed comparable bandstop designs to tart up the performance of the measuring receivers.
Old 22nd Mar 2020, 5:02 pm   #26
TonyDuell
My late father assembled a Texan from the kit from Henry's Radio. He used it for the rear channel speakers of a quadraphonic setup (remember those?). I still have the Texan, I must get it going again.
But the real reason for this post is that some years ago I was given an instrument that was otherwise going in the skip 'You might get some useful bits from it'. It turned out to be a Radford DMS3A distortion meter. I didn't know how respected they were back then but I kept it and didn't raid it for part.
What I don't have is a suitable low distortion oscillator to use with it. Should I try making one?
TonyDuell is offline
Old 22nd Mar 2020, 6:42 pm   #27
Craig Sawyers
I tried looking for the spec of the Radford, and there is a dearth of information out there. I found mention that it is good to 0.001% (10ppm) which is pretty good, and a useful number. You should really be aiming for ten times lower distortion in a test signal (ie oscillator), so 1ppm. Doing that and providing a variable frequency is not straighforward.
Oddly I found this document while searching, which is an interesting read (I just did a quick scan) http://www.angelfire.com/ab3/mjramp/distortiontest.pdf
This is the guy's website http://www.renardson-audio.com/ which seems to have a load of interesting stuff on there,
Craig
Old 22nd Mar 2020, 7:38 pm   #28
Radio Wrangler
Of course, the Radford distortion meter is the perfect instrument to use when developing an oscillator to go with it. It may floor out at 0.001% but when you've developed an oscillator good enough to show only little above that floor, then you've reached the 1ppm sort of level that Craig mentions. You don't need to find a 0.0001% distortion meter to check your oscillator.
Remember to keep a sense of proportion. The hardest thing is to know when you've done enough. A good many respected and sought after amplifiers have distortion figures orders of magnitude more than this level.
One of the best bits of a distortion meter is to stick a scope or spectrum analyser on the distortion residual output and look at the frequency content coming out. As said above, low order distortion products are significant parts of music and voices. Higher order ones sound unnatural and get noticed. This might be a good application for a soundcard/PC/Software spectrum analysis app.
I gave my brother a distortion meter as a christmas present a few years ago. He messes around with guitars and guitar amplifiers. I said he might find it useful to check that he was getting enough distortion
