Old 13th Jul 2018, 5:07 pm   #1
Dorian27
Default U17204/1 transistor or equivalent
Can any one tell me where I can get a transistor for my dansette amp it is a Z109 board and the transistor no is U17204/1 or can any one give me an equivalent no for one please many thanks dorian27
Dorian27 is offline   Reply With Quote
Old 13th Jul 2018, 5:35 pm   #2
GeoffK
Default Re: U17204/1 transistor or equivalent
This is a NPN driver transistor. BC107, BC108 or BFY50, BFY51, BFY52 are suitable replacements. Check the output transistors base bias current is set to correct value. If the driver transistor has failed then the cause should be investigated first as the driver is usually reliable, it is the output transistors that are more likely to fail. These can fail when the base bias variable resistor goes high resistance or open circuit.
Geoff
GeoffK is offline   Reply With Quote
Old 13th Jul 2018, 11:10 pm   #3
Dorian27
Thanks very much
