14th Aug 2013, 6:32 pm | #1 |
Interfacing a brother AX25 to a computer
I have a brother AX25 that has a 15way D connector on the side for a computer interface. This is for an IF20 interface that converts from centronics. I am guessing that the 15 way D connector.
Pins 1,2,3,4 appear to be ground Pins 8,15 are +5 volts The others appear to TTL level, and I suspect that there are 7 data bits, a strobe and a busy. Does anyone have the pinout of this connector to save me some experimentation or the circuit diagram of a brother IF20 interface, or a brother typewriter with this interface on (eg AX25 but it has been used on a lot of typewriters). Also is there a magic key combination required to turn the typewriter into online mode? Thank you. |
15th Aug 2013, 1:31 pm | #2 |
Re: Interfacing a brother AX25 to a computer
can you show a picture of the connections on the back ?
15th Aug 2013, 6:29 pm | #3 |
I have not worked out how to dismantle the typewriter as I cannot remove the platern to get the top off. The connector for the interface is the same as used for the game port on a PC - although the functionality will be totally different. I hope that helps.
15th Aug 2013, 7:42 pm | #4 |
15th Aug 2013, 8:14 pm | #5 |
Actually I know the connector, just not the signals that I have to supply on each pin of the connector which is what I would like the help with.
