15th Nov 2010, 6:15 pm | #1 |
Enhanced variac .......
Although some of the more experienced members may already be doing this I thought it might be useful to newcomers.
Some will be familiar with the mains power meter gadgets now available that can monitor various parameters of appliances or equipment plugged into them, the type that plugs into a normal mains socket and then the equipment to be used is plugged into the monitor. For a while now I have been using one of these in conjunction with a variac when soft powering up unknown radios etc , in doing so the current, voltage, power and frequency can be directly viewed on the power monitors display as the voltage is increased. This is very useful as it is then easy to see that all is ok as the equipment is gradually powered up. The current drawn for the average table top valve receiver is soon established and should one see a higher than anticipated value it can be investigated before potential damage is caused. As a case in point I was powering up a Philco 471 yesterday evening and it was drawing 2-3 times more current than I was used to seeing from the type at about 115v so I know there is a problem to be investigated before going any further. The power monitor I have was bought from Aldi of all places for £9.99 and it's a very useful thing to have. |
24th Nov 2010, 12:23 pm | #2 |
Re: Enhanced variac .......
also use fuse for overcurrent protection, it helps
24th Nov 2010, 10:35 pm | #3 | |
Al
I won't tell you how I discovered that. |
